Cisco 1921 won't pass Traffic
thomas.waterman
Hello all. I am hoping someone can point out in the attached config where I have cause a problem. I can telnet to the router and ping places on the inside and outside. However when I connect a laptop to the inside interface I can ping to the outside for a bit but can't open a web page and then connectivity is gone all together. At first I thought it was a NAT issue but I know I am good on that front. I have attempted to change the speeds and duplex settings on the outside interface but it dioes not seem to help. Again if I take the cable from the outside interface and plug it into a laptop it works fine. The thing that makes me wonder is why can I connect to the outside interface and configue it just fine?
Thank you for your assistance.
Tom
Can you try replacing this
ip nat pool IOWNAT xx.37.0.211 xx.37.0.211 netmask 255.255.255.128
ip nat source list 1 pool IOWNAT overload
access-list 1 permit 192.168.6.0 0.0.0.255 log
with this
access-list 1 permit 192.168.6.0 0.0.0.255 any
ip nat inside source list 1 interface gi0/1 overload
check with "sh ip nat tran"
Reza Sharifi
Your config looks good.  Can you try adding this command to the inside interface and test again?
ip tcp adjust-mss 1412
OK I added that to the inside interface but still no luck.
with this
Thank you so much for the help! It works perfectly now!
