Cisco 1941 Router - Portforwarding
svenkasier
Hello Everyone,
I am trying to portforward on my Cisco 1941 Router.
The situation:
ISP Router: 192.168.0.1 (WAN IP: x.x.x.x)
 - DMZ: 192.168.0.114
Cisco Router: int g0/1 : 20.30.40.1
     int g0/0 : 192.168.0.114
I want an IP inside the 20.30.40.* range to listen on port 3389
My routers config is the following:
Building configuration...
Current configuration : 3341 bytes
version 15.2
service password-encryption
hostname S1941C
boot-start-marker
boot-end-marker
enable secret 4 *****
enable password 7 ****
no aaa new-model
ip cef
ip dhcp excluded-address 20.30.40.75 20.30.40.200
ip dhcp pool pool1
 network 20.30.40.0 255.255.255.0
 domain-name ChesterHOME.local
 dns-server 8.8.8.8 1.2.3.4
 default-router 20.30.40.1
 lease 0 23
no ipv6 cef
crypto pki trustpoint TP-self-signed-3125917043
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-3125917043
 revocation-check none
 rsakeypair TP-self-signed-3125917043
crypto pki certificate chain TP-self-signed-3125917043
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33313235 39313730 3433301E 170D3134 31303237 31363538
  33375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 31323539
  31373034 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100A49C A7F0DCF6 5A08F59B 2F7879B3 94775E42 3666A648 1ADE8252 DE34B1E5
  C8F1FFD0 54DA870A 890280C1 DBE7C0B5 1D0D2D73 FFA15207 BC498DAB D74AE032
  665C0161 36866E44 26BA9807 FC12A04E 1E2D4F35 840BC08F 6CA38F52 9B00EE8E
  B66EB4E5 CEB90937 35D68A46 B238B751 7749FD11 AD250E7D ADF76D89 A3E4CB87
  A1610203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14DC1BA0 D4986172 D3892A02 865CB2EC 686C2943 02301D06
  03551D0E 04160414 DC1BA0D4 986172D3 892A0286 5CB2EC68 6C294302 300D0609
  2A864886 F70D0101 05050003 81810077 8168C141 C1B743D9 7F3FE88A 4714738E
  DC12700C 5D60D613 38A6D99C 72DCA45A CE7BD1A7 BA46A7C5 EE424BA7 CAB72E1F
  EDE6FEF9 FA376AD7 54B9C003 DEEE327D 768F2735 A724CF90 CBB054BD 318270A0
  892D231C E88A71EB 93F93889 F7A575B3 F6F7FD13 5A95EAEE 1B40F8DC CB7B6243
  1B5B7B48 CB6EF5C9 6798BD28 31CD4E
        quit
license udi pid CISCO1941/K9 sn *****
username Chester privilege 15 secret 4 ********
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address dhcp
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 no mop enabled
interface GigabitEthernet0/1
 ip address 20.30.40.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
 no mop enabled
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 100 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.0.1
access-list 100 permit ip 20.30.40.0 0.0.0.255 any
control-plane
banner motd c ** c
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 privilege level 15
 login local
 transport input telnet ssh
scheduler allocate 20000 1000
end
Is anyone able to help me?
Thanks in advance
2 Accepted Solutions
Ultimately, this is what needs to happen.
Internet traffic needs to flow to your ISP router, which will "DMZ" forward everything it doesn't have a NAT entry for to 192.168.0.114. It doesn't need any kind of routing for this because 192.168.0.0/24 is directly-connected.
Your Cisco 1921 needs to forward traffic from its WAN interface's 3389/tcp port to 20.30.40.53's 3389/tcp port. It also needs to have a static route to the Internet via 192.168.0.1, which it already has. No other routing needs to be configured because everything else is directly-connected.
Relevant configuration is as follows:
 ip address 192.168.0.114 255.255.255.0
 ip nat outside
 ip nat inside
ip nat inside source static tcp 20.30.40.53 3389 interface GigabitEthernet0/0 3389
The inside machine should use address 20.30.40.53, subnet mask 255.255.255.0 and gateway 20.30.40.1.
It looks like I typoed the 3389/tcp forwarding command earlier in the conversation and had things running off of the wrong interface. It's corrected in the commands above.
That should make everything work.
Jody Lemoine, Network Architect
CCIE 41436, MTCRE, MTCINE, MTCIPv6E
tishco networks, Virtually Everywhere
(905) 378-1134, jody.lemoine@tishco.ca
That will do it.
I'm glad I could be of help. If you could rate any more helpful comments and mark one or more as correct, I would appreciate it.
34 Replies 34
ghostinthenet
Level 7
Level 7
You should be able to do this with the following command:
ip nat inside source static tcp 20.30.40.x 3389 interface GigabitEthernet0/1 3389
Once this is in place, connections to GigabitEthernet0/1's dynamic IPv4 address on 3389/tcp will forward to 20.30.40.x on 3389/tcp.
Does not work.
So to be clear, what I am trying to do, is connect to the 20.30.40.* by coming from an extern connection. In another building other network. a standard RDP session.
thanks in advance
What result do you get when you attempt to connect to the GigabitEthernet0/1 address on 3389/tcp from a machine on the 192.168.0.0/24 network?
Also, can you telnet to 20.30.40.x on 3389/tcp from the router using GigabitEthernet0/1 as the source?
I don't know how I can test the connectivity on that exact port :/
What I can do is acces the router from the 192.168.0.0 range.. (http only)
Thanks in advance..
From a machine on 192.168.0.0/24:
telnet 192.168.0.a 3389
From the router:
telnet 20.30.40.a 3389 /source GigabitEthernet0/1
Thanks, output:
From the router: Connection timed out. remote host not responding.
From a machine: does not work also..
So I don't really see the problem.. :/
Looks like it might be a gateway issue on the host or a firewall problem.
Do these work from the router?
ping 20.30.40.a
telnet 20.30.40.a 3389 - ... open
ping 20.30.40.a - works from the 20.30.40.1 router
still I can't connect via rdp to the machine.
from an external server ofc.
So I think; when i RDP to my ISP's IP: **.*.***.**:3389 it does not route correctly?
This definitely sounds like a gateway problem. Can you check the machine you're forwarding to and make sure it has a correct default gateway and subnet mask? The fact that you can ping from the LAN interface of the router, but not from its WAN interface is telling.
My gateway is 192.168.0.114, right?
When I test via open port, port 3389 is not open..
Thanks in advance!
No. The gateway has to be on the same subnet, so it should be 20.30.40.1.
Tried that, not working...
It's strange, the port isn't open on my WANIP
The port is forwarded, but if there's nothing answering at the other end, it won't be open. So the target machine has 20.30.40.x as an IPv4 address, 255.255.255.0 as the subnet mask and 20.30.40.1 as the gateway? Can it successfully connect outbound to the Internet?
Yes as you can see in screenshot attached.
Everything works fine on the host.
