Cisco 1941w sharing VDSL
karlosthehat
Hi everyone, newb here.
I picked up a cheap 1941w, but know very little about them and as such this is a very steep learning curve. This particular one has a VDSL2 module and 1x 8 port POE gigabit module. I have a VLAN that covers 8x POE gigabit ports which is my main network, a separate admin VLAN and then share the VDSL to both of these.
So far all is good, I am connected to the internet (my ISP has assigned a static IP and it displays correctly) but I can't figure out how to share it to my VLAN's or the router itself. I found some other threads on the topic but they are all related to FTTP etc and I can't get it to work with VDSL2. If I try to test the WAN connection or ping something, it doesn't work despite being connected to the internet. My ISP tool says I am synced but I can't ping the router.
Any help appreciated!
config:
Using 5380 out of 262136 bytes
! Last configuration change at 22:38:06 UTC Wed Nov 17 2021 by thepoint
version 15.6
hostname thepoint
boot-start-marker
boot-end-marker
enable secret 5 xxxxx
enable password xxxxx
no aaa new-model
memory-size iomem 5
service-module wlan-ap 0 bootimage autonomous
ip dhcp excluded-address 192.168.1.1
ip dhcp pool admin
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
ip dhcp pool LAN
import all
network 192.168.1.0 255.255.255.0
dns-server 8.8.8.8
default-router 192.168.1.1
ip cef
no ipv6 cef
flow record nbar-appmon
match ipv4 source address
match ipv4 destination address
match application name
collect interface output
collect counter bytes
collect counter packets
collect timestamp absolute first
collect timestamp absolute last
flow monitor application-mon
cache timeout active 60
record nbar-appmon
parameter-map type inspect global
max-incomplete low 18000
max-incomplete high 20000
nbar-classify
license udi pid CISCO1941W-N/K9 sn FGL163823NB
hw-module ism 0
object-group service INTERNAL_UTM_SERVICE
object-group network Others_dst_net
any
object-group network Others_src_net
any
object-group service Others_svc
ip
object-group network Web_dst_net
any
object-group network Web_src_net
any
object-group service Web_svc
ip
object-group network local_cws_net
object-group network local_lan_subnets
object-group network vpn_remote_subnets
any
username thepoint privilege 15 secret 5 xxxxx
redundancy
controller VDSL 0/0/0
operating mode vdsl2
class-map type inspect match-any INTERNAL_DOMAIN_FILTER
match protocol msnmsgr
match protocol ymsgr
class-map type inspect match-any Others_app
match protocol https
match protocol smtp
match protocol pop3
match protocol imap
match protocol sip
match protocol ftp
match protocol dns
match protocol icmp
class-map type inspect match-any Web_app
match protocol http
class-map type inspect match-all Others
match class-map Others_app
match access-group name Others_acl
class-map type inspect match-all Web
match class-map Web_app
match access-group name Web_acl
policy-map type inspect LAN-WAN-POLICY
class type inspect Web
inspect
class type inspect Others
inspect
class class-default
drop log
zone security LAN
zone security WAN
zone security VPN
zone security DMZ
zone-pair security LAN-WAN source LAN destination WAN
service-policy type inspect LAN-WAN-POLICY
crypto isakmp policy 1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
ip tcp adjust-mss 1412
duplex auto
speed auto
no mop enabled
interface wlan-ap0
no ip address
arp timeout 0
no mop enabled
no mop sysid
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Wlan-GigabitEthernet0/0
switchport mode trunk
no ip address
interface ATM0/0/0
no ip address
shutdown
no atm ilmi-keepalive
cdp enable
interface Ethernet0/0/0
description PrimaryWANDesc_
ip address dhcp
ip nat outside
interface GigabitEthernet0/1/0
no ip address
interface GigabitEthernet0/1/1
no ip address
interface GigabitEthernet0/1/2
no ip address
interface GigabitEthernet0/1/3
no ip address
interface GigabitEthernet0/1/4
no ip address
interface GigabitEthernet0/1/5
no ip address
interface GigabitEthernet0/1/6
no ip address
interface GigabitEthernet0/1/7
no ip address
interface Vlan1
ip nbar protocol-discovery
ip flow monitor application-mon input
ip flow ingress
ip flow egress
ip nat inside
zone-member security LAN
load-interval 30
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 1 interface Ethernet0/0/0 overload
ip nat inside source list nat-list interface Ethernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 Ethernet0/0/0
ip access-list extended Others_acl
permit object-group Others_svc object-group Others_src_net object-group Others_dst_net
ip access-list extended Web_acl
permit object-group Web_svc object-group Web_src_net object-group Web_dst_net
ip access-list extended nat-list
permit ip object-group local_lan_subnets any
deny ip any any
snmp-server community thepoint RO
access-list 1 permit 192.168.2.0 0.0.0.255
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 1 permit 0.0.0.1 255.255.255.0
control-plane
vstack
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
line vty 0 4
password xxxxxx
login
transport input none
scheduler allocate 20000 1000
end
make the changes marked in bold:
version 15.6
hostname thepoint
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip dhcp pool admin
ip dhcp pool LAN
import all
dns-server 8.8.8.8
ip cef
no ipv6 cef
record nbar-appmon
nbar-classify
hw-module ism 0
any
any
ip
any
any
ip
any
redundancy
match protocol smtp
match protocol pop3
match protocol imap
match protocol sip
match protocol ftp
match protocol dns
match protocol icmp
match protocol http
inspect
inspect
class class-default
drop log
zone security LAN
zone security WAN
zone security VPN
zone security DMZ
no ip address
shutdown
ip nat inside
duplex auto
speed auto
no mop enabled
interface wlan-ap0
no ip address
arp timeout 0
no mop enabled
no mop sysid
no ip address
shutdown
duplex auto
speed auto
no ip address
interface ATM0/0/0
no ip address
shutdown
cdp enable
ip address dhcp
ip nat outside
--> zone-member security WAN
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip flow ingress
ip flow egress
ip nat inside
load-interval 30
ip http server
--> no ip nat inside source list nat-list interface Ethernet0/0/0 overload
--> ip route 0.0.0.0 0.0.0.0 Ethernet0/0/0 dhcp
--> no ip access-list extended nat-list
deny ip any any
--> no access-list 1 permit 0.0.0.1 255.255.255.0
control-plane
vstack
line con 0
line aux 0
line 2
no exec
stopbits 1
line 67
no exec
transport input all
line vty 0 4
password xxxxxx
login
end
pieterh
do i overlook an "ip routing" statement ?
version 15.6
hostname thepoint
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip dhcp pool admin
ip dhcp pool LAN
import all
dns-server 8.8.8.8
ip cef
no ipv6 cef
record nbar-appmon
nbar-classify
hw-module ism 0
any
any
ip
any
any
ip
any
redundancy
match protocol smtp
match protocol pop3
match protocol imap
match protocol sip
match protocol ftp
match protocol dns
match protocol icmp
match protocol http
inspect
inspect
class class-default
drop log
zone security LAN
zone security WAN
zone security VPN
zone security DMZ
no ip address
shutdown
ip nat inside
duplex auto
speed auto
no mop enabled
interface wlan-ap0
no ip address
arp timeout 0
no mop enabled
no mop sysid
no ip address
shutdown
duplex auto
speed auto
no ip address
interface ATM0/0/0
no ip address
shutdown
cdp enable
ip address dhcp
ip nat outside
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip flow ingress
ip flow egress
ip nat inside
load-interval 30
ip http server
deny ip any any
control-plane
vstack
line con 0
line aux 0
line 2
no exec
stopbits 1
line 67
no exec
transport input all
line vty 0 4
password xxxxxx
login
end
karlosthehat
Hi there,
Thanks for the replies! You are correct that there was no ip route, but I have made all of the suggested changes with no luck.
WAN shows connected, VDSL has synced and I have an IP address but none of my VLAN's can access the internet. I can ping remote servers successfully from Ethernet0/0/0 and 192.168.1.1, so this is definitely a routing issue.
I have tidied up the config and will post below
Any more ideas? Thanks!
Using 3457 out of 262136 bytes
! Last configuration change at 22:00:53 UTC Thu Nov 18 2021 by thepoint
version 15.6
hostname thepoint
boot-start-marker
boot-end-marker
enable secret 5 xxxxxxxxxxx
enable password xxxxxxxxxxxxx
no aaa new-model
memory-size iomem 5
ip dhcp excluded-address 192.168.0.1
ip dhcp pool admin
ip dhcp pool LAN
import all
ip domain name thepoint.com
ip cef
no ipv6 cef
record nbar-appmon
hw-module ism 0
any
any
username thepoint privilege 15 secret 5 xxxxxxxxxxxxxxxx
redundancy
zone security LAN
zone security WAN
zone security VPN
zone security DMZ
no ip address
shutdown
no ip address
duplex auto
speed auto
interface wlan-ap0
no ip address
arp timeout 0
no mop enabled
no mop sysid
ip nat inside
duplex auto
speed auto
no mop enabled
no ip address
shutdown
interface ATM0/0/0
no ip address
shutdown
cdp enable
ip address dhcp
ip nat outside
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
interface Vlan1
ip nat inside
ip http server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
control-plane
vstack
line con 0
line aux 0
line 2
no exec
stopbits 1
line 67
no exec
transport input all
line vty 0 4
password xxxxxxxxx
login local
transport input ssh
end
karlosthehat
Success! It turns out I hadn't configured any firewall policies yet (d'oh!). So the routing was all good, just being blocked by the firewall. Here are the changes  I made:
deny ip any any
Thanks again for your help, much appreciated.
