Cisco 2503 as a DHCP server
swapniljain
I have a cisco 2503 router, everything is working fine. i want to configure it as a DHCP server to serv LAN users. but the command are not working. the ios version is 11.3
any support appriciated.
Swapnil Jain
hi swapnil,
sorry for that because i cant do it...
but you can serch it on the web, i found some thing like "IOS Hunter" when i was studying so they are allowing me to have some ios download...
try to search on google IOS HUNTER and they are charging something like 60$ but you can go for trial version it will allow to download some free IOS...
http://www.vitaltech-group.com/IOSHunter.htm
hope this will help you
rate the posts if it helps
regards
Devang
9 Replies 9
devang_etcom
Level 7
Level 7
http://www.cisco.com/en/US/tech/tk648/tk361/tech_configuration_guides_list.html
look at this link here you will find the configuration detail for DHCP...
try this and still if you have query then let us know...
regards
Devang
thanks devang
but i have tried this, the service dhcp command doesn't work. i think the ios doesn't support dhcp.
swapnil jain
one thing you can do is just check out the ios configuration guide, if there is any dhcp configuration command is there then its okay otherwise you have to go for the IOS upgrade which is supported by your hardware as well as that ios should support the dhcp configuration...
thanks for your reply
regards
Devang
where can i get a newer IOS, it has 11.3
Swapnil Jain
swapnil
you have to download it from the cisco website and for that you need username and password to login...
so just talk to your employer if they have access to download IOS then only you can...
regards
Devang
Devang
well we dont have a username password which would allow me download a valid ios. can u help me in that.
Swapnil Jain
hi swapnil,
regards
Devang
thanks a lot Devang,
the trial version is allowing me to download the 12.1 for 2500, i'll test it
thanks a lot
Swapnil Jain
no problem...
you are always wellcome
regards
Devang
