cisco 2800 series router
Srinivas N
Hi Friends,
I have 2800 series router,
I have one public IP 115.119.187.x, and DNS IPs 121.242.190.180, 121.242.190.211
I want to configure the router for nearly 50 no of PCs for internet.
Please help me how to configure that router (cisco 2800) step by step,
since i am new to this config.
my understand is i need to configure nating, dhcp and dns.... is it ok?
is there required any access list?
Please help me step by step
Srinivas. N.
Thanks & Regards,
Srinivas.
Peter Paluch
Hello Srinivas,
This should be a fairly simple task.
Please use the following configuration, adapting it in IP addresses as necessary.
interface FastEthernet0/0
description => Internal LAN network <=
ip address 10.0.0.1 255.255.255.0
ip nat inside
no shutdown
exit
interface FastEthernet0/1
description => Internet connection <=
ip address 115.119.187.x M.M.M.M ! Insert the correct address and mask
ip nat outside
no shutdown
exit
ip route 0.0.0.0 0.0.0.0 G.G.G.G ! Insert the correct ISP's gateway address
ip dhcp excluded-address 10.0.0.0 10.0.0.10
ip dhcp pool LAN
network 10.0.0.0 /24
default-router 10.0.0.1
dns-servers 121.242.190.180 121.242.190.211
exit
ip access-list standard NAT
permit 10.0.0.0 0.0.0.255
exit
ip nat inside source list NAT interface FastEthernet0/1 overload
Here I assume that your PCs will be connected to Fa0/0 interface via an external switch, and your 2800 router will be connected to the ISP via Fa0/1 interface.
Please feel welcome to ask further.
Best regards,
Peter
7 Replies 7
Peter Paluch
Hello Srinivas,
ip nat inside
no shutdown
exit
ip nat outside
no shutdown
exit
ip dhcp pool LAN
exit
exit
Best regards,
Peter
Hi Peter,
Thanks for u r reply,
with below config it is working file.
User Access Verification
Password:
Router>en
Password:
Router#sh run
Building configuration...
Current configuration : 1279 bytes
version 15.0
hostname Router
boot-start-marker
boot-end-marker
enable password xxxx
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.0 192.168.1.10
ip dhcp pool ADMIN-II
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 121.242.190.x 121.242.190.x
license udi pid CISCO2811 sn FHK1450F1PV
redundancy
interface Loopback0
no ip address
description # WAN Network #
ip address 115.119.187.x 255.255.255.x
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
description # Lan Network #
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 10 interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 115.119.187.x
access-list 10 permit any
control-plane
line con 0
line aux 0
line vty 0 4
password xxxx
login
scheduler allocate 20000 1000
end
Router#
Thanks & Regards,
Srinivas.
Hi peter,
for the same router, plz tel me how to config bandwidth limit.
I need to config 1Mbps for fa0/1.
Srinivas. N.
Thanks & Regards,
Srinivas.
Hello Srinivas,
There is one problem in your configuration - your access-list 10 is currently of the form permit any. This configuration might work but officially, it is not supported and Cisco insists very strongly that an ACL used for NAT is made more specific.
I suggest correcting your ACL by entering the following commands:
no access-list 10
access-list 10 permit 192.168.1.0 0.0.0.255
In addition, if you want to perform rate limiting on Fa0/1, add these lines to the configuration:
policy-map fa0/1-out
class class-default
  fair-queue
  shape average 1000000
interface fa0/1
service-policy output fa0/1-out
Best regards,
Peter
Hellow Peter,
I really appreshate your quick reply...
I will modify and for retelimit i given the command...
for fa0/1
rate-limit input 1024000 192000 384000 conform-action transmit exceed-action drop
rate-limit output 1024000 192000 384000 conform-action transmit exceed-action drop
It won't make any issue?
Srinivas. N
Thanks & Regards,
Srinivas.
Hi Peter,
I just follow this but doesn´t work in my side! I can ping from PC to LAG gateway and WAN port but not the ISP gateway and from Router I cannot ping any PC in my network!
Please assist.
Luis
Hi Srinivas,
Apply a rate-limit on f0/1 interface.
Sent from Cisco Technical Support Android App
