Cisco 2801 FTP timeout with Archive commands
dmaldonado03
Hello all,
I’m applying the archive commands to routers and switches on our network. So far all the switches are transferring successfully to the ftp server. The problem I’m running into is the routers. When I write the config and do a "show archive"   I get this:
Archive #  Name
   1        :Error - Timed out <- Most Recent
   2        :Error - Timed out
Any help is appreciated.
Heres the current configuration:
version 15.0
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
service udp-small-servers
service tcp-small-servers
hostname Rockport2801
boot-start-marker
boot-end-marker
card type t1 0 2
logging buffered 4096
enable secret 5 $1$h7iD$1ugt50a3jBF3noi5xlbS9.
enable password 7 106D063941033207
no aaa new-model
clock timezone Central -6
clock summer-time CDT recurring
no network-clock-participate wic 2
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
voice-card 0
license udi pid CISCO2801 sn FTX143300D6
archive
path
ftp://cisco:k33p!t$!mpl3@68.65.156.121/CPMHMR/$h
write-memory
controller T1 0/2/0
cablelength long 0db
channel-group 1 timeslots 1-24
controller T1 0/2/1
ip ftp username cisco
ip ftp password 7 09471D5A094403564A01142678
class-map match-all citrix
match access-group 150
class-map match-all video
match access-group 107
class-map match-all voice
match access-group 105
policy-map QoS_Rockport
class citrix
    priority 896
class voice
    priority 256
class class-default
    fair-queue
policy-map policy1
class voice
    priority 256
class video
    bandwidth 896
class class-default
    fair-queue
policy-map policy2
class video
    bandwidth 896
class class-default
    fair-queue
interface FastEthernet0/0
description ***Rockport MH LAN***
ip address 168.XX.XX.2 255.255.255.192
ip helper-address 168.XX.XX.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/2/0:1
ip address 168.XX.XX.142 255.255.255.252
service-policy output QoS_Rockport
interface Serial0/2/1:1
ip address 168.XX.XX.169 255.255.255.252
service-policy output policy2
router eigrp 1
network 168.XX.XX.140 0.0.0.3
network 168.XX.XX.168 0.0.0.3
network 168.XX.XX.0 0.0.0.63
no eigrp log-neighbor-changes
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 168.XX.XX.141
ip route 168.XX.XX.0 255.255.0.0 168.XX.XX.141
access-list 107 permit ip host 168.XX.XX.87 any
access-list 107 permit ip host 168.XX.XX.3 any
access-list 107 permit ip host 168.XX.XX.179 any
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.110 eq 3389
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.109 eq 3389
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.108 eq 3389
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.107 eq 3389
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.106 eq 3389
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.110 eq www
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.109 eq www
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.108 eq www
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.107 eq www
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.106 eq www
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.110 eq 443
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.109 eq 443
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.108 eq 443
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.107 eq 443
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.106 eq 443
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.110 eq 8080
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.109 eq 8080
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.108 eq 8080
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.107 eq 8080
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.106 eq 8080
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.110 eq 1494
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.109 eq 1494
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.108 eq 1494
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.107 eq 1494
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.106 eq 1494
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.110 eq 2598
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.109 eq 2598
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.108 eq 2598
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.107 eq 2598
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.106 eq 2598
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.110 eq 2512
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.109 eq 2512
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.108 eq 2512
access-list 150 permit tcp 168.XX.XX.0 0.0.0.63 host 168.XX.XX.107 eq 2512
line con 0
exec-timeout 30 0
password 7 132618324F182426
login
transport preferred none
line aux 0
exec-timeout 30 0
password 7 02250B7B4F122F2D
login local
modem InOut
transport input all
stopbits 1
line vty 0 4
exec-timeout 30 0
password 7 0802436E4D0D251B
login
line vty 5 15
exec-timeout 30 0
login
scheduler allocate 20000 1000
end
0 Replies 0
