Cisco 2801 no ip dhcp use vrf connected
DavidHall86437
I have this issue also but when i get to this code encapsulation dot1Q 10 i can not go further
c(config-subif)#encapsulation.1Q 10
% Invalid input detected at '^' marker.
i have tried as spelt in original post still comes to this.
i have tried the responses in a previous discussion as above but no luck
kapydan88
Level 4
Level 4
It looks, like you have some syntax error.
What is your device and what is your purpose?
Try this way
interface GigabitEthernet0/0.19
description ...
encapsulation dot1Q 19
ip address 10.192.19.1 255.255.255.0
end
kapydan88
Level 4
Level 4
Try this way
description ...
end
I have been trying to configure s cisco 2801 but can not get it working correctly i did a check and vrf was not working so i found a discussion that listed that line sequence.
I will give it a try and let you know
Thanks for that now i have another stop
H38elec(config-subif)#ip vrf forwarding MyVRF1
% VRF MyVRF1 not configured.
The code line following is below is it because FA should be Fe if not please let me know
ip vrf MyVRF1
rd 1:1
ip vrf MyVRF2
rd 1:2
ip dhcp pool Global
network 192.0.2.0 /24
ip dhcp pool ForMyVRF1
vrf MyVRF1
ip dhcp pool ForMyVRF2
vrf MyVRF2
interface Fa0/0.10
ip address 192.0.2.1 255.255.255.0
interface Fa0/0.20
encapsulation dot1Q 20
interface Fa0/0.30
encapsulation dot1Q 30
ip vrf forwarding MyVRF2
