Cisco 2801 password reset
A.K.M. Sayeed
One of my remote office router model is Cisco 2801. Unfortunately I forgot the telnet/vty password of that router. I am sitting 500 KM distance in between in the Head Office. I can ping the router but due to lost password I cannot login to the router. Moreover I dont have snmp enabled in that router. So this option is out of question.
Is there anyway I can reset the router's password remotely from my head office. Additionaly I have a switch directly connected to the router and I can ping and login to the swtich but not the router. I am writing this about the switch if the help resetting the routers password anyway.
Please help me.
Sayeed
garapoglou
Level 3
Level 3
Unfortunately you cannot reset the password remotelly. You have to connect to the router via the console port and this needs your physical presence.
This document will help you out:
http://www.cisco.com/en/US/products/hw/routers/ps259/products_password_recovery09186a0080094675.shtml
Best regards,
Giorgos
