11-13-2013 04:12 AM - edited 03-04-2019 09:34 PM
Dear All,
One cisco 2801 router is rebooting frequently. What might be the issue? Please find the logs below -
------------------ show version ------------------
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(20)T5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Mon 08-Mar-10 05:35 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
TRIVANDRUM uptime is 7 minutes
System returned to ROM by error - a System Error, PC 0x400550E0 at 13:40:56 IST Wed Nov 13 2013
System restarted at 13:42:34 IST Wed Nov 13 2013
System image file is "flash:c2800nm-advipservicesk9-mz.124-20.T5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 2811 (revision 53.51) with 512000K/12288K bytes of memory.
Processor board ID FHK1420F0RP
2 FastEthernet interfaces
1 Serial(sync/async) interface
1 ISDN Basic Rate interface
2 Virtual Private Network (VPN) Modules
DRAM configuration is 64 bits wide with parity enabled.
191K bytes of non-volatile configuration memory.
126000K bytes of ATA CompactFlash (Read/Write)
Amarjit Das
11-13-2013 04:20 AM
Paste the output of:
show stacks
if you have any crashinfo file in flash then please also attach that.
http://www.cisco.com/en/US/products/hw/iad/ps397/products_tech_note09186a00800b4447.shtml
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00800cdd51.shtml
11-13-2013 04:24 AM
Hi Sandeep,
sh stac
Router#sh stacks
Minimum process stacks:
Free/Size Name
5424/6000 Inspect Init Msg
5376/6000 SPAN Subsystem
5364/6000 FLEX DSPRM boot download main
58960/60000 EEM Auto Registration Proc
4116/6000 Auto Upgrade Startup Process
5120/6000 DIB error message
5424/6000 SASL MAIN
2420/3000 allegro libretto init
4912/6000 LICENSE AGENT DEFAULT
10880/12000 Router Init
59164/60000 script background loader
4216/6000 Update prst
2736/12000 Init
4476/6000 VPN_HW_MIB_CREATION
5212/6000 RADIUS INITCONFIG
2140/3000 Rom Random Update Process
11204/12000 IPRM
34092/36000 TCP Command
9152/12000 Virtual Exec
Interrupt level stacks:
Level Called Unused/Size Name
1 14638 5220/9000 Network interfaces
2 127423 8596/9000 DMA/Timer Interrupt
3 1 8268/9000 PA Management Int Handler
4 200 8612/9000 Console Uart
5 0 9000/9000 External Interrupt
7 141180 8564/9000 NMI Interrupt Handler
System was restarted by error - a System Error, PC 0x40055014 at 17:36:18 IST Wed Nov 13 2013
Image text-base: 0x4000F900, data-base: 0x43DA59F0
Stack trace from system failure:
FP: 0x47FE5A40, RA: 0x40055014
FP: 0x47FE5B78, RA: 0x40011564
******* Information of Last System Crash **********
Using flash:crashinfo_20131113-120620.
*Nov 13 11:49:52.823: %VPN_HW-6-INFO_LOC: Crypto engine: aim 0 State changed to: Initialized
*Nov 13 11:49:52.843: %VPN_HW-6-INFO_LOC: Crypto engine: aim 0 State changed to: Enabled
*Nov 13 11:50:14.651: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Initialized
*Nov 13 11:50:14.655: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Disabled Installed image archive
*Nov 13 11:50:16.447: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Nov 13 11:50:16.447: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
*Nov 13 11:50:16.447: %LINK-3-UPDOWN: Interface FastEthernet0/1, changed state to up
*Nov 13 11:50:16.451: %LINK-3-UPDOWN: Interface Serial0/1/0, changed state to upCisco 2811 (revision 49.46) with 512000K/12288K bytes of memory.
*Nov 13 11:50:17.843: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to up
*Nov 13 11:50:17.843: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to down
*Nov 13 11:50:17.843: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0, changed state to upCMD: 'version 12.4' 11:50:18 UTC Wed Nov 13 2013
CMD: 'service nagle' 11:50:18 UTC Wed Nov 13 2013
CMD: 'no service pad' 11:50:18 UTC Wed Nov 13 2013
CMD: 'service tcp-keepalives-in' 11:50:18 UTC Wed Nov 13 2013
CMD: 'service tcp-keepalives-out' 11:50:18 UTC Wed Nov 13 2013
CMD: 'service timestamps debug datetime msec localtime show-timezone' 11:50:18 UTC Wed Nov 13 2013
CMD: 'service timestamps log datetime msec localtime show-timezone' 11:50:18 UTC Wed Nov 13 2013
CMD: PASSWORD statement not printed
CMD: 'no service dhcp' 11:50:18 UTC Wed Nov 13 2013
CMD: 'hostname TRIVANDRUM' 11:50:18 UTC Wed Nov 13 2013
CMD: 'boot-start-marker' 11:50:18 UTC Wed Nov 13 2013
CMD: 'boot-end-marker' 11:50:18 UTC Wed Nov 13 2013
CMD: 'logging message-counter syslog' 11:50:18 UTC Wed Nov 13 2013
CMD: 'aaa new-model' 11:50:18 UTC Wed Nov 13 2013
CMD: 'aaa authentication attempts login 5' 11:50:18 UTC Wed Nov 13 2013
CMD: 'aaa authentication banner ^CC' 11:50:18 UTC Wed Nov 13 2013
CMD: 'aaa authentication login CSACS group tacacs+ local' 11:50:18 UTC Wed Nov 13 2013
CMD: 'aaa authentication login consoleport local' 11:50:18 UTC Wed Nov 13 2013
CMD: 'aaa authorization exec UBI group tacacs+ local none ' 11:50:18 UTC Wed Nov 13 2013
CMD: 'aaa authorization commands 1 default group tacacs+ local ' 11:50:18 UTC Wed Nov 13 2013
CMD: 'aaa authorization commands 15 default group tacacs+ local ' 11:50:18 UTC Wed Nov 13 2013
CMD: 'aaa accounting commands 15 default start-stop group tacacs+' 11:50:18 UTC Wed Nov 13 2013
CMD: 'aaa session-id common' 11:50:18 UTC Wed Nov 13 2013
CMD: 'clock timezone IST 5 30' 11:50:18 UTC Wed Nov 13 2013
*Nov 13 17:20:18.251 IST: %SYS-6-CLOCKUPDATE: System clock has been updated from 11:50:18 UTC Wed Nov 13 2013 to 17:20:18 IST Wed Nov 13 2013, configured from console by console.CMD: 'clock calendar-valid' 17:20:18 IST Wed Nov 13 2013
CMD: 'dot11 syslog' 17:20:18 IST Wed Nov 13 2013
CMD: 'no ip source-route' 17:20:18 IST Wed Nov 13 2013
CMD: 'ip cef' 17:20:18 IST Wed Nov 13 2013
CMD: 'no ip bootp server' 17:20:18 IST Wed Nov 13 2013
CMD: 'no ip domain lookup' 17:20:18 IST Wed Nov 13 2013
CMD: 'ip domain name cisco.com' 17:20:18 IST Wed Nov 13 2013
CMD: 'no ipv6 cef' 17:20:18 IST Wed Nov 13 2013
CMD: 'multilink bundle-name authenticated' 17:20:18 IST Wed Nov 13 2013
CMD: 'isdn switch-type basic-net3' 17:20:18 IST Wed Nov 13 2013
% Invalid input detected at '^' marker.
CMD: 'voice-card 0' 17:20:18 IST Wed Nov 13 2013
CMD: ' no dspfarm' 17:20:18 IST Wed Nov 13 2013
CMD: 'crypto isakmp policy 1' 17:20:18 IST Wed Nov 13 2013
CMD: ' encr 3des' 17:20:18 IST Wed Nov 13 2013
CMD: ' hash md5' 17:20:18 IST Wed Nov 13 2013
CMD: ' authentication pre-share' 17:20:18 IST Wed Nov 13 2013
CMD: 'crypto ipsec transform-set dmvpn esp-3des esp-md5-hmac ' 17:20:18 IST Wed Nov 13 2013
CMD: 'crypto ipsec df-bit clear' 17:20:18 IST Wed Nov 13 2013
CMD: 'crypto map vpn local-address Loopback100' 17:20:18 IST Wed Nov 13 2013
CMD: 'crypto map vpn 36 ipsec-isakmp ' 17:20:18 IST Wed Nov 13 2013
CMD: ' set peer 192.168.3.5' 17:20:18 IST Wed Nov 13 2013
CMD: ' set transform-set dmvpn ' 17:20:18 IST Wed Nov 13 2013
CMD: ' match address 191' 17:20:18 IST Wed Nov 13 2013
CMD: 'crypto map vpn 37 ipsec-isakmp ' 17:20:18 IST Wed Nov 13 2013
CMD: 'archive' 17:20:18 IST Wed Nov 13 2013
CMD: ' log config' 17:20:18 IST Wed Nov 13 2013
CMD: ' hidekeys' 17:20:18 IST Wed Nov 13 2013
CMD: 'ip ftp username ubi' 17:20:18 IST Wed Nov 13 2013
CMD: 'ip ssh time-out 60' 17:20:18 IST Wed Nov 13 2013
CMD: 'ip ssh authentication-retries 2' 17:20:18 IST Wed Nov 13 2013
CMD: 'ip ssh version 2' 17:20:18 IST Wed Nov 13 2013
CMD: 'class-map match-any VOICE' 17:20:18 IST Wed Nov 13 2013
CMD: ' match access-group name VOICE' 17:20:18 IST Wed Nov 13 2013
CMD: ' match ip dscp ef ' 17:20:18 IST Wed Nov 13 2013
CMD: 'policy-map QOS' 17:20:18 IST Wed Nov 13 2013
CMD: ' class VOICE' 17:20:18 IST Wed Nov 13 2013
CMD: ' priority 16' 17:20:18 IST Wed Nov 13 2013
CMD: ' set ip dscp ef' 17:20:18 IST Wed Nov 13 2013
CMD: 'interface Loopback100' 17:20:18 IST Wed Nov 13 2013
CMD: ' ip address 192.168.101.4 255.255.255.255' 17:20:18 IST Wed Nov 13 2013
CMD: ' no ip redirects' 17:20:18 IST Wed Nov 13 2013
CMD: ' no ip proxy-arp' 17:20:18 IST Wed Nov 13 2013
CMD: 'interface Loopback1000' 17:20:18 IST Wed Nov 13 2013
CMD: ' no ip address' 17:20:18 IST Wed Nov 13 2013
CMD: 'interface FastEthernet0/0' 17:20:18 IST Wed Nov 13 2013
CMD: ' ip address 192.168.206.62 255.255.255.248 secondary' 17:20:18 IST Wed Nov 13 2013
CMD: ' ip address 172.29.133.254 255.255.255.128' 17:20:18 IST Wed Nov 13 2013
CMD: ' no ip unreachables' 17:20:18 IST Wed Nov 13 2013
CMD: ' ip flow ingress' 17:20:18 IST Wed Nov 13 2013
CMD: ' duplex auto' 17:20:18 IST Wed Nov 13 2013
CMD: ' speed auto' 17:20:18 IST Wed Nov 13 2013
CMD: 'interface FastEthernet0/1' 17:20:18 IST Wed Nov 13 2013
CMD: ' shutdown' 17:20:18 IST Wed Nov 13 2013
CMD: 'interface BRI0/0/0' 17:20:18 IST Wed Nov 13 2013
interface BRI0/0/0
CMD: ' bandwidth 64' 17:20:19 IST Wed Nov 13 2013
bandwidth 64
CMD: ' no ip address' 17:20:19 IST Wed Nov 13 2013
no ip address
% Incomplete command.
CMD: ' encapsulation ppp' 17:20:19 IST Wed Nov 13 2013
encapsulation ppp
CMD: ' dialer pool-member 150' 17:20:19 IST Wed Nov 13 2013
CMD: ' isdn switch-type basic-net3' 17:20:19 IST Wed Nov 13 2013
CMD: ' isdn point-to-point-setup' 17:20:19 IST Wed Nov 13 2013
Nov 13 17:20:19.623 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback100, changed state to upCMD: 'interface Serial0/1/0' 17:20:19 IST Wed Nov 13 2013
CMD: ' backup delay 3 5' 17:20:19 IST Wed Nov 13 2013
CMD: ' backup interface Dialer150' 17:20:19 IST Wed Nov 13 2013
CMD: ' ip address 192.168.103.10 255.255.255.252' 17:20:19 IST Wed Nov 13 2013
CMD: ' ip tcp header-compression iphc-format' 17:20:19 IST Wed Nov 13 2013
CMD: ' load-interval 30' 17:20:19 IST Wed Nov 13 2013
CMD: ' crypto map vpn' 17:20:19 IST Wed Nov 13 2013
CMD: ' service-policy output QOS' 17:20:19 IST Wed Nov 13 2013
Nov 13 17:20:19.791 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback1000, changed state to upCMD: ' ip rtp header-compression iphc-format' 17:20:19 IST Wed Nov 13 2013
CMD: 'interface Dialer150' 17:20:19 IST Wed Nov 13 2013
CMD: ' description *** ISDN BACKUP ****** ISDN-BACKUP ***' 17:20:19 IST Wed Nov 13 2013
CMD: ' ip address 192.168.229.142 255.255.252.0' 17:20:19 IST Wed Nov 13 2013
CMD: ' no ip redirects' 17:20:19 IST Wed Nov 13 2013
CMD: ' no ip unreachables' 17:20:19 IST Wed Nov 13 2013
CMD: ' no ip proxy-arp' 17:20:19 IST Wed Nov 13 2013
CMD: ' ip ospf network broadcast' 17:20:19 IST Wed Nov 13 2013
CMD: ' ip ospf priority 0' 17:20:19 IST Wed Nov 13 2013
CMD: ' dialer pool 150' 17:20:19 IST Wed Nov 13 2013
CMD: ' dialer idle-timeout 3660' 17:20:19 IST Wed Nov 13 2013
CMD: ' dialer fast-idle 100' 17:20:19 IST Wed Nov 13 2013
CMD: ' dialer string 04424955390' 17:20:20 IST Wed Nov 13 2013
CMD: ' dialer hold-queue 10' 17:20:20 IST Wed Nov 13 2013
CMD: ' dialer-group 1' 17:20:20 IST Wed Nov 13 2013
CMD: ' ppp authentication chap' 17:20:20 IST Wed Nov 13 2013
CMD: ' crypto map vpn' 17:20:20 IST Wed Nov 13 2013
CMD: 'router ospf 10' 17:20:20 IST Wed Nov 13 2013
CMD: ' log-adjacency-changes' 17:20:20 IST Wed Nov 13 2013
CMD: ' network 172.29.133.128 0.0.0.127 area 29' 17:20:20 IST Wed Nov 13 2013
CMD: 'ip forward-protocol nd' 17:20:20 IST Wed Nov 13 2013
CMD: 'ip route 0.0.0.0 0.0.0.0 Serial0/1/0' 17:20:20 IST Wed Nov 13 2013
CMD: 'ip route 0.0.0.0 0.0.0.0 Dialer150 50' 17:20:20 IST Wed Nov 13 2013
CMD: 'no ip http server' 17:20:20 IST Wed Nov 13 2013
CMD: 'no ip http secure-server' 17:20:20 IST Wed Nov 13 2013
CMD: 'ip tacacs source-interface Loopback100' 17:20:20 IST Wed Nov 13 2013
CMD: 'ip access-list extended VOICE' 17:20:20 IST Wed Nov 13 2013
CMD: ' permit udp any any range 16384 32767' 17:20:20 IST Wed Nov 13 2013
CMD: ' permit udp any range 16384 32767 any' 17:20:20 IST Wed Nov 13 2013
CMD: ' permit tcp any range 2000 2002 any' 17:20:20 IST Wed Nov 13 2013
CMD: ' permit tcp any any range 2000 2002' 17:20:20 IST Wed Nov 13 2013
CMD: 'ip sla 1' 17:20:20 IST Wed Nov 13 2013
CMD: ' icmp-echo 172.16.19.1 source-ip 172.29.133.254' 17:20:20 IST Wed Nov 13 2013
CMD: ' frequency 10' 17:20:20 IST Wed Nov 13 2013
CMD: 'ip sla schedule 1 life forever start-time now' 17:20:20 IST Wed Nov 13 2013
CMD: 'ip sla schedule 2 life forever start-time now' 17:20:20 IST Wed Nov 13 2013
CMD: 'logging 172.16.19.103' 17:20:20 IST Wed Nov 13 2013
CMD: 'access-list 75 permit 151.200.10.16' 17:20:20 IST Wed Nov 13 2013
CMD: 'access-list 75 permit 172.16.0.0 0.15.255.255' 17:20:20 IST Wed Nov 13 2013
CMD: 'access-list 191 deny ospf any any' 17:20:20 IST Wed Nov 13 2013
CMD: 'access-list 191 permit ip 172.29.133.128 0.0.0.127 172.16.0.0 0.0.255.255' 17:20:20 IST Wed Nov 13 2013
CMD: 'dialer-list 1 protocol ip permit' 17:20:20 IST Wed Nov 13 2013
CMD: 'snmp-server ifindex persist' 17:20:20 IST Wed Nov 13 2013
CMD: 'tacacs-server host 172.16.144.15' 17:20:20 IST Wed Nov 13 2013
CMD: 'control-plane' 17:20:20 IST Wed Nov 13 2013
CMD: 'banner login ^CC' 17:20:20 IST Wed Nov 13 2013
CMD: 'line con 0' 17:20:20 IST Wed Nov 13 2013
CMD: 'line aux 0' 17:20:20 IST Wed Nov 13 2013
CMD: ' no exec' 17:20:20 IST Wed Nov 13 2013
CMD: 'line vty 0 4' 17:20:20 IST Wed Nov 13 2013
CMD: ' access-class 75 in' 17:20:20 IST Wed Nov 13 2013
CMD: ' authorization exec UBI' 17:20:20 IST Wed Nov 13 2013
CMD: ' login authentication CSACS' 17:20:20 IST Wed Nov 13 2013
CMD: ' transport input telnet ssh' 17:20:20 IST Wed Nov 13 2013
CMD: 'scheduler allocate 20000 1000' 17:20:20 IST Wed Nov 13 2013
CMD: 'ntp source Loopback100' 17:20:20 IST Wed Nov 13 2013
CMD: 'ntp update-calendar' 17:20:20 IST Wed Nov 13 2013
CMD: 'ntp server 192.168.11.1' 17:20:20 IST Wed Nov 13 2013
CMD: 'end' 17:20:20 IST Wed Nov 13 2013
Nov 13 17:20:20.575 IST: %SYS-5-CONFIG_I: Configured from memory by consoleCMD: 'access-list 199 permit icmp host 10.10.10.10 host 20.20.20.20' 17:20:20 IST Wed Nov 13 2013
CMD: 'crypto map NiStTeSt1 10 ipsec-manual' 17:20:20 IST Wed Nov 13 2013
CMD: 'match address 199
CMD: 'set peer 20.20.20.20
CMD: 'exit' 17:20:20 IST Wed Nov 13 2013
CMD: 'no access-list 199' 17:20:20 IST Wed Nov 13 2013
CMD: 'no crypto map NiStTeSt1' 17:20:20 IST Wed Nov 13 2013
Nov 13 17:20:21.067 IST: %LINK-5-CHANGED: Interface FastEthernet0/1, changed state to administratively down
Nov 13 17:20:21.487 IST: %SYS-5-RESTART: System restarted --
Nov 13 17:20:21.495 IST: %SNMP-5-COLDSTART: SNMP agent on host TRIVANDRUM is undergoing a cold start
Nov 13 17:20:21.555 IST: %SSH-5-ENABLED: SSH 2.0 has been enabled
Nov 13 17:20:21.731 IST: Di150 DDR: dialer shutdown complete
Nov 13 17:20:21.751 IST: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
Nov 13 17:20:21.751 IST: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
Nov 13 17:20:21.751 IST: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
Nov 13 17:20:23.783 IST: %LINK-5-CHANGED: Interface Dialer150, changed state to standby mode
Nov 13 17:20:23.967 IST: %SYS-6-BOOTTIME: Time taken to reboot after reload = 254 seconds
Nov 13 17:20:24.163 IST: %OSPF-5-ADJCHG: Process 10, Nbr 192.168.100.1 on Serial0/1/0 from LOADING to FULL, Loading Done
Nov 13 17:20:24.235 IST: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 172.16.19.103 port 514 started - CLI initiated
Nov 13 17:20:24.235 IST: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 172.16.19.100 port 514 started - CLI initiatedSDRAM ECC Error,
err addr - 0x836C720F, err data_l 0x10235264,err data_h 0x75F3C3CE,
rcv ecc - 0xB4000000, calc ecc 0x84000000, err cnt 0x1B020000
r0 = FFFFFFFF r1 = FFFFFFFF r2 = 0 r3 = 46960000 r4 = 0
r5 = 0 r6 = 0 r7 = 0 r8 = 0 r9 = 46D22BE0
r10 = 0 r11 = 0 r12 = 0 r13 = 0 r14 = 0
r15 = 0 r16 = 0 r17 = C r18 = 0 r19 = 2EB2
r20 = 0 r21 = 2EB1 r22 = 0 r23 = CE3 r24 = 0
r25 = CE2 r26 = 0 r27 = 0 r28 = 0 r29 = 4000
r30 = 0 r31 = 40000000 r32 = FFFFFFFF r33 = FFFFFFFF r34 = FFFFFFFF
r35 = FFFFFFFF r36 = FFFFFFFF r37 = FFFFFFFF r38 = FFFFFFFF r39 = FFFFFFFF
r40 = FFFFFFFF r41 = FFFFFFFF r42 = FFFFFFFF r43 = FFFFFFFF r44 = FFFFFFFF
r45 = FFFFFFFF r46 = FFFFFFFF r47 = FFFFFFFF r48 = 0 r49 = 8000000
r50 = 0 r51 = 2EB7 r52 = 0 r53 = 0 r54 = 0
r55 = 0 r56 = FFFFFFFF r57 = FFFFFFFF r58 = 0 r59 = 47FE5A40
r60 = FFFFFFFF r61 = FFFFFFFF r62 = 0 r63 = 40011564
sreg = 3400F903 mdlo_hi = 0 mdlo = 401F964
mdhi_hi = FFFFFFFF mdhi = F8CB9683 badvaddr_hi = FFFFFFFF
badvaddr = FFFFFFFF cause = FFFFFFFF epc_hi = 0
epc = 40055014 err_epc_hi = FFFFFFFF err_epc = FFFFFFFF
%ERR-1-FATAL: Fatal error interrupt, reloading
err_stat=0x0
=== Flushing messages (17:36:19 IST Wed Nov 13 2013) ===
Queued messages:
17:36:19 IST Wed Nov 13 2013: Interrupt exception, CPU signal 22, PC = 0x0
Possible software fault. Upon reccurence, please collect
crashinfo, "show tech" and contact Cisco Technical Support.
-Traceback=
$0 : 00000000, AT : 00000000, v0 : 00000000, v1 : 00000000
a0 : 00000000, a1 : 00000000, a2 : 00000000, a3 : 00000000
t0 : 00000000, t1 : 00000000, t2 : 00000000, t3 : 00000000
t4 : 00000000, t5 : 00000000, t6 : 00000000, t7 : 00000000
s0 : 00000000, s1 : 00000000, s2 : 00000000, s3 : 00000000
s4 : 00000000, s5 : 00000000, s6 : 00000000, s7 : 00000000
t8 : 00000000, t9 : 00000000, k0 : 00000000, k1 : 00000000
gp : 00000000, sp : 00000000, s8 : 00000000, ra : 00000000
EPC : 00000000, ErrorEPC : 00000000, SREG : 00000000
MDLO : 00000000, MDHI : 00000000, BadVaddr : 00000000
DATA_START : 0x43DA59F0
Cause 00000000 (Code 0x0): Interrupt exception
=== Start of Crashinfo Collection (17:36:20 IST Wed Nov 13 2013) ===
For image:
========= Show Alignment =============================
No alignment data has been recorded.
No spurious memory references have been recorded.
========= Malloc and Free Traces=====================
MallocFree Trace: ixmallocfree=0x2E ptr=0x46D28300
46D28190: 492C7CC8 40090A84 492A61DC 40090A98 496CBBDC 40090A84 49174164 40090A98
46D281B0: 495E2BD4 40090A98 4801B610 40090A84 48055A74 40090A98 493CC6DC 40090A84
46D281D0: 493CA7F4 40090A98 48351DD4 40090A84 47A6C340 40090A98 49755964 30000DA2
46D281F0: 49755964 4266298C 49755964 40092510 49755964 30000DA2 49755964 4266298C
46D28210: 49755964 40092510 485DA6DC 43D1C344 49635838 43931358 481EAF58 43939010
46D28230: 493EC338 43939018 493EC76C 60000442 493F876C 439313B8 493F8A30 6000014A
46D28250: 47A6C840 43931358 47A6C490 43939010 47A6C588 60000012 49755530 43939018
46D28270: 49755964 60000DA2 47A6BAD8 439313B8 47A6BD9C 600002BA 49755530 30000FBC
46D28290: 49755530 4266298C 49755530 40092510 49755530 30000FBC 49755530 4266298C
46D282B0: 49755530 40092510 480FFAD0 4000017C 480FFAD0 40808C3C 480FFAD0 40092510
46D282D0: 480FFDF8 60000050 49755530 30000FBC 49755530 4266298C 49755530 40092510
46D282F0: 49755530 30000FBC 49755530 4266298C 49755530 40092510 4967B010 40090A84
46D28310: 49209E88 40090A98 494638BC 40090A84 49209F18 40090A98 49453888 40090A84
46D28330: 49209FA8 40090A98 4965E30C 40090A84 495E3918 40090A98 4966E340 40090A98
46D28350: 496C4644 40090A84 492B3D48 40090A98 496C9498 40090A84 491742D0 40090A98
46D28370: 491717BC 40090A84 4920B14C 40090A98 492B4C74 40090A84 4805B608 40090A98
========= Chunk Malloc and Chunk Free Traces=====================
46D27FC4: 4943E310 41DD3F00 41DD2AA8 47FD10E4 4012C0B4 4012AA04
46D27FAC: 493B2CC8 42E15A14 42E186CC 47FCF44C 42E15A14 42E1877C
46D27F94: 47FD1EC8 4011ACF8 4012AA58 47FD24E0 4011A6C0 4012AAA0
46D27F7C: 47FD2508 4011A6C0 4012AAA0 47FD2508 4011A78C 4012AAA0
46D27F64: 47FD1EC8 4011A654 4012AA58 47FCF44C 42E19698 42E1877C
46D27F4C: 493B2CC8 42E17694 42E186CC 493B2CC8 42E15A14 42E186CC
46D27F34: 47FCF44C 42E15A14 42E1877C 47FD1EC8 4011ACF8 4012AA58
46D27F1C: 47FD2508 4011A6C0 4012AAA0 47FD2508 4011A78C 4012AAA0
46D27F04: 47FD1EC8 4011A654 4012AA58 47FCF44C 42E19698 42E1877C
46D27EEC: 493B2CC8 42E17694 42E186CC 493B2CC8 42E15A14 42E186CC
46D27ED4: 47FCF44C 42E15A14 42E1877C 47FD1EC8 4011ACF8 4012AA58
46D27EBC: 47FD2508 4011A6C0 4012AAA0 47FD2508 4011A78C 4012AAA0
46D27EA4: 47FD1EC8 4011A654 4012AA58 47FCF44C 42E19698 42E1877C
46D2818C: 493B2CC8 42E17694 42E186CC 493B2CC8 42E15A14 42E186CC
46D28174: 47FCF44C 42E15A14 42E1877C 47FD1EC8 4011ACF8 4012AA58
46D2815C: 47FD2508 4011A6C0 4012AAA0 47A0BE04 40121630 4012A9B0
46D28144: 47A0BE28 40121630 4012A9B0 47FD2508 4011A78C 4012AAA0
46D2812C: 47FD1EC8 4011A654 4012AA58 47FCF44C 42E19698 42E1877C
46D28114: 493B2CC8 42E17694 42E186CC 493B2CC8 42E15A14 42E186CC
46D280FC: 47FCF44C 42E15A14 42E1877C 47FD1EC8 4011ACF8 4012AA58
46D280E4: 47FD2508 4011A6C0 4012AAA0 47FD2508 4011A78C 4012AAA0
46D280CC: 47FD1EC8 4011A654 4012AA58 47FCF44C 42E19698 42E1877C
46D280B4: 493B2CC8 42E17694 42E186CC 493B2CC8 42E15A14 42E186CC
46D2809C: 47FCF44C 42E15A14 42E1877C 47FD1EC8 4011ACF8 4012AA58
46D28084: 47FD2508 4011A6C0 4012AAA0 47A0BE04 40121558 4012A9B0
46D2806C: 47A0BE28 40121558 4012A9B0 47FD2508 4011A78C 4012AAA0
46D28054: 47FD1EC8 4011A654 4012AA58 47FCF44C 42E19698 42E1877C
46D2803C: 493B2CC8 42E17694 42E186CC 493B2CC8 42E15A14 42E186CC
46D28024: 47FCF44C 42E15A14 42E1877C 47FD1EC8 4011ACF8 4012AA58
46D2800C: 47FD2508 4011A6C0 4012AAA0 47AC1148 41DCDAF4 41DCC560
46D27FF4: 47FD2508 4011A78C 4012AAA0 47FD1EC8 4011A654 4012AA58
46D27FDC: 47FCF44C 42E19698 42E1877C 493B2CC8 42E17694 42E186CC
========== Stack Trace========
-Traceback=
========= Context ======================
Signal = 0, Code = 0x0, Uptime 00:18:03
EPC : 00000000, SREG : 00000000, Cause : 00000000
Error EPC : 00000000, BadVaddr : 00000000
========= Stack Dump ==========================
Stack Frame Pointer in Context is 0x0, at process level
: INVALID STACK ADDRESS
========= Process Level Info ==================
---- Current Process Block (at 0x48B1C14C) ----
48B1C11C: AB1234CD B70000 B7 45A96144 42E12E30 48B1C418 48B1C05C 80000166
48B1C13C: 1 0 BE 48339A9C 48A69F10 48A6B5E0 4295B3F8 0
48B1C15C: 48D0EC5C 46D20000 0 46C40000 46C40000 466F0000 46950000 43DB0000
48B1C17C: 0 48A6B660 0 42E152C8 0 0 4295B3F8 0
48B1C19C: 10000 1 0 0 0 4 B7 4295B454
48B1C1BC: 42E151E0 0 0 0 1C24 1C24 0 0
48B1C1DC: B7 0 0 107B0C 0 0 0 107B0C
48B1C1FC: 0 107B0C 14 0 8C3 493F34A4 39E29 0
48B1C21C: 4593F4C8 4 8 3D7 3CA 3AF 1770 1770
48B1C23C: 479F5F98 0 0 0 0 0 0 0
48B1C25C: 482A7450 48B1C14C 46D275D8 0 4947B928 46D27AB8 46961C28 48B1C2B4
48B1C27C: 0 107B10 421C 0 0 0 48B1C26C 0
48B1C29C: 0 0 42A0 48B1C14C 0 0 0 48B1C2B4
48B1C2BC: 48B1C26C 48B1C14C 0 107B10 142EC 0 0 0
48B1C2DC: 48B1C26C 48B1C14C 0 0 242E4 0 0 0
48B1C2FC: 0 0 0 48D0EC5C 0 0 0 0
48B1C31C: 0 0 0 0 0 48D0ECF4 48B1C31C 48D0EC64
48B1C33C: 0 473944E8 0 0 0 0 0 0
48B1C35C: 0 FFFFFFF FFFFFFF 0 0 0 0 1FC18
48B1C37C: 0 0 0 48B1C448 0 0 32 0
48B1C39C: 0 0 48A6B6B4 0 0 19610 940 482ECD50
48B1C3BC: 482ECD50 48339AF0 48D0EC6C 48B1C3B8 46C6B7C8 BD9 D0000 1
48B1C3DC: 0 45A961B8 42E0CE24 4679F234 0 48339A9C 0 0
48B1C3FC: 0 0 0 0 BEEFCAFE 0
---- Partial decode of process block ----
Pid 183: Process "HQF Shaper Background" stack 0x48A69F10 savedsp 0x48A6B5E0
Flags: analyze prefers_new
Status 0x00000000 Orig_ra 0x00000000 Routine 0x4295B3F8 Signal 0
Caller_pc 0x4295B454 Callee_pc 0x42E151E0 Dbg_events 0x00000000 State 4
Totmalloc 0 Totfree 0 Totgetbuf 0
Totretbuf 0 Edisms 0x0 Eparm 0x0
Elapsed 0x14 Ncalls 0x39E29 Ngiveups 0x0
Priority_q 4 Ticks_5s 8 Cpu_5sec 983 Cpu_1min 970
Cpu_5min 943 Stacksize 0x1770 Lowstack 0x1770
Ttyptr 0x479F5F98 Mem_holding 0x1C24 Thrash_count 0
Wakeup_reasons 0x0FFFFFFF Default_wakeup_reasons 0x0FFFFFFF
Direct_wakeup_major 0x00000000 Direct_wakeup_minor 0x00000000
Preempted processes context:
Regs s0-s8,ra at last suspend; a0,a1,sp from proc creation, PC unused:
a0: 4295B3F8 a1: 00000000 s0: 48D0EC5C s1: 46D20000 s2: 00000000
s3: 46C40000 s4: 46C40000 s5: 466F0000 s6: 46950000 s7: 43DB0000
s8: 00000000 sp: 48A6B660 PC: 00000000 ra: 42E152C8
---- Current Process Stack (0x138 bytes used, out of 0x1770 available) ----
Current SP = 0x0 , saved SP = 0x48A6B5E0
48A6B548: 0 107B0C FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
48A6B568: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 48B1C2B4 2 42E15280 46C3A878
48A6B588: 46C40000 466F0000 0 107B10 0 107B14 48D0EC5C 46D20000
48A6B5A8: 0 46C40000 46C40000 466F0000 46950000 42E0E128 0 42967C50
48A6B5C8: 48D0EC5C 46D20000 42E15280 46C40000 48D0EC5C 42E152B8 0 1
48A6B5E8: 80 46C40000 4295B454 466F0000 0 1 80 4295B45C
48A6B608: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 1 0 0 0
48A6B628: 0 0 0 0 0 0 42E03C40 FFFFFFFF
48A6B648: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 42E03C24 FFFFFFFF FFFFFFFF FFFFFFFF
48A6B668: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
========= Interrupt Level Stack Dump ==========
WARNING: Interrupt stack dumps are consistent ONLY for interrupts which
are blocked during exception handling. Also register output is valid
ONLY for interrupts which store an r4k_context block on the stack.
---- Level 1 Interrupt stack (0xEC4 bytes used, out of 0x2328 available) ----
intstacks[1]: base 0x47FE3854 stack 0x47FE5B78 routine 0x0 count 0x616B
size 0x2328 low 0x2328 desc 0x43FF5410
47FE577C: 40DA2140 47F13108 0 0 47F13108 4952EAF4 1 3F6F4A04
47FE579C: 47FE57C1 49580002 48126190 44E00000 47F13108 0 46950000 482759F4
47FE57BC: 47F13108 43BF2BD0 47F13108 8 2F 0 481B8C88 2F
47FE57DC: 43DB0000 0 437B0BB0 0 0 0 47F13108 4820362C
47FE57FC: 1400002F 473B6E80 439999E0 0 33 46950000 0 0
47FE581C: 437C1494 4820362C 47F13108 48142C58 46950000 3 43993C30 47FE5880
47FE583C: 0 3F6F9024 47F13108 3F6F9024 47F13108 48142C58 46950000 3
47FE585C: 0 1 43996840 47F13108 1F13108 483DEA34 0 47AA0860
47FE587C: 40327E5C 48C75D9C 4001A7B4 3F6F9024 47F13108 3F6F9024 47F13108 1C
47FE589C: 2 47FE58CC 4880A5C9 4880A598 41B98B44 481420DC 49593370 20000
47FE58BC: 4296A5F8 47F13108 2 0 0 25DF1F0 481420DC 21
47FE58DC: 15 10 481420DC 1B 46B7A3E8 FF B9 3
47FE58FC: 40020DA8 FFFFF7FF 48143A8C 46D70000 0 10000 0 1
47FE591C: 41B98B44 481420DC 481B8280 47F13108 F6EAE80 8 481B8280 47F13108
47FE593C: F6EAE80 0 40019034 0 47F13108 40019B28 1 1
47FE595C: 41B98534 F6EAD20 48143CB0 20 0 1F 1 481A839C
47FE597C: 0 48143610 C 100000 3 42E1AB20 46D20000 46000000
47FE599C: 46510000 40015D2C 40015A7C 481420DC 46D70000 0 46010000 0
47FE59BC: 40045A10 10000002 4000 800000 0 0 46D70000 0
47FE59DC: 0 4600C650 4000FD84 FFFFFFFF 800001 FFFFFFFF FFFFFFFF 46D762F0
47FE59FC: 40054FE0 F 0 4000 4000 40011564 40011534 0
47FE5A1C: 0 0 40054FE0 0 46010000 0 495D6C7C 400550B0
47FE5A3C: FFFFFFFF FFFFFFFF FFFFFFFF 0 46960000 0 1 0
47FE5A5C: 0 0 495DF024 0 1 0 46959250 0
47FE5A7C: 0 0 0 0 107B0C 0 46959254 0
47FE5A9C: 0 0 46010000 0 1 0 47390000 0
47FE5ABC: 0 0 1 0 0 0 F 0
47FE5ADC: 1 0 495D6B70 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
47FE5AFC: FFFFFFFF 0 47380000 0 0 0 3040A801 FFFFFFFF
47FE5B1C: A000F000 FFFFFFFF FFFFFFFF 0 47A81A88 FFFFFFFF FFFFFFFF 0
47FE5B3C: 400655B4 3400FF03 FFFFFFFF 0 401F964 FFFFFFFF F8CB9683 FFFFFFFF
47FE5B5C: FFFFFFFF FFFFFFFF FFFFFFFF 0 400655E8 FFFFFFFF FFFFFFFF FFFFFFFF
$0 : FFFFFFFF, AT : 46960000, v0 : 00000001, v1 : 00000000
a0 : 495DF024, a1 : 00000001, a2 : 46959250, a3 : 00000000
t0 : 00000000, t1 : 00107B0C, t2 : 46959254, t3 : 00000000
t4 : 46010000, t5 : 00000001, t6 : 47390000, t7 : 00000000
s0 : 00000001, s1 : 00000000, s2 : 0000000F, s3 : 00000001
s4 : 495D6B70, s5 : FFFFFFFF, s6 : FFFFFFFF, s7 : FFFFFFFF
t8 : 47380000, t9 : 00000000, k0 : 3040A801, k1 : A000F000
gp : FFFFFFFF, sp : 47A81A88, s8 : FFFFFFFF, ra : 400655B4
EPC : 400655E8, ErrorEPC : FFFFFFFF, SREG : 3400FF03
MDLO : 0401F964, MDHI : F8CB9683, BadVaddr : FFFFFFFF
---- Level 2 Interrupt stack (0x194 bytes used, out of 0x2328 available) ----
intstacks[2]: base 0x47FE152C stack 0x47FE3850 routine 0x4027FD94 count 0x43318
size 0x2328 low 0x2328 desc 0x43FF8BA4
47FE36C0: 0 46D762C4 B4000000 1 4027FEA0 4027FEA0 FFFFFFFF FFFFFFFF
47FE36E0: FFFFFFFF FFFFFFFF 1 0 46D27008 0 F 1
47FE3700: 492D3208 46010000 492D3314 495D6C7C 4600C650 4005533C FFFFFFFF FFFFFFFF
47FE3720: 0 46960000 0 0 0 492D3314 0 492D3208
47FE3740: 0 46D20000 0 0 0 46D20000 0 0
47FE3760: 0 1 0 43DB0000 0 46990000 0 46D20000
47FE3780: 0 4739437C 0 47390000 0 0 FFFFFFFF FFFFFFFF
47FE37A0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
47FE37C0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 0 0
47FE37E0: 0 0 0 3040A801 FFFFFFFF A000F000 FFFFFFFF FFFFFFFF
47FE3800: 0 47A81A88 FFFFFFFF FFFFFFFF 0 40065598 3400FF03 FFFFFFFF
47FE3820: 0 7530 0 0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
47FE3840: 0 42E140CC FFFFFFFF FFFFFFFF FFFFFFFF
$0 : FFFFFFFF, AT : 46960000, v0 : 00000000, v1 : 492D3314
a0 : 492D3208, a1 : 46D20000, a2 : 00000000, a3 : 46D20000
t0 : 00000000, t1 : 00000001, t2 : 43DB0000, t3 : 46990000
t4 : 46D20000, t5 : 4739437C, t6 : 47390000, t7 : 00000000
s0 : FFFFFFFF, s1 : FFFFFFFF, s2 : FFFFFFFF, s3 : FFFFFFFF
s4 : FFFFFFFF, s5 : FFFFFFFF, s6 : FFFFFFFF, s7 : FFFFFFFF
t8 : 00000000, t9 : 00000000, k0 : 3040A801, k1 : A000F000
gp : FFFFFFFF, sp : 47A81A88, s8 : FFFFFFFF, ra : 40065598
EPC : 42E140CC, ErrorEPC : FFFFFFFF, SREG : 3400FF03
MDLO : 00007530, MDHI : 00000000, BadVaddr : FFFFFFFF
---- Level 3 Interrupt stack (0x2DC bytes used, out of 0x2328 available) ----
intstacks[3]: base 0x47FDF204 stack 0x47FE1528 routine 0x4027D098 count 0x1
size 0x2328 low 0x2328 desc 0x43FF545C
47FE1250: 40944AD8 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 49209B44 0
47FE1270: 1 0 0 480C6BE8 409401B4 0 1 16
47FE1290: 1 2 49209B44 40943D24 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
47FE12B0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
47FE12D0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
47FE12F0: FFFFFFFF FFFFFFFF 100 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 49209AB8
47FE1310: 11 49209A28 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
47FE1330: FFFFFFFF FFFFFFFF 40944BF8 FFFFFFFF FFFFFFFF FFFFFFFF 49209AB8 46E1CE20
47FE1350: 49209AB8 46E1CE20 46370000 0 0 480C6BE8 40944E6C 40944E8C
47FE1370: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFF 0 BFA00000 8
47FE1390: 46D75FFC 40010390 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 46D7666C 1
47FE13B0: 46D75FFC BFB40000 49209B44 480C6BE8 4027D134 FFFFFFFF FFFFFFFF FFFFFFFF
47FE13D0: FFFFFFFF FFFFFFFF 8FFFF FFFFFFFF BFB40004 15 49209AB8 40055538
47FE13F0: FFFFFFFF FFFFFFFF 0 46960000 FFFFFFFF BFA00000 FFFFFFFF BFA00000
47FE1410: 0 49209AB8 0 8FF8 0 480C6BE8 0 5
47FE1430: 0 F4240 0 186A0 0 186A00 FFFFFFFF FFFFFFFF
47FE1450: FFFFFFFF FB5C9EE4 0 51EB0000 0 C8 0 5
47FE1470: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
47FE1490: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
47FE14B0: 0 3EC 0 3ED 0 3040A801 FFFFFFFF A000F000
47FE14D0: FFFFFFFF FFFFFFFF 0 480C6B90 FFFFFFFF FFFFFFFF 0 40944DBC
47FE14F0: 3400FF03 FFFFFFFF 0 C8 0 4 FFFFFFFF FFFFFFFF
47FE1510: FFFFFFFF FFFFFFFF 0 4003F21C FFFFFFFF FFFFFFFF FFFFFFFF
$0 : FFFFFFFF, AT : 46960000, v0 : BFA00000, v1 : BFA00000
a0 : 49209AB8, a1 : 00008FF8, a2 : 480C6BE8, a3 : 00000005
t0 : 000F4240, t1 : 000186A0, t2 : 00186A00, t3 : FFFFFFFF
t4 : FB5C9EE4, t5 : 51EB0000, t6 : 000000C8, t7 : 00000005
t8 : 000003EC, t9 : 000003ED, k0 : 3040A801, k1 : A000F000
gp : FFFFFFFF, sp : 480C6B90, s8 : FFFFFFFF, ra : 40944DBC
EPC : 4003F21C, ErrorEPC : FFFFFFFF, SREG : 3400FF03
MDLO : 000000C8, MDHI : 00000004, BadVaddr : FFFFFFFF
---- Level 4 Interrupt stack (0x184 bytes used, out of 0x2328 available) ----
intstacks[4]: base 0x47FDCEDC stack 0x47FDF200 routine 0x40284638 count 0xBB
size 0x2328 low 0x2328 desc 0x43FF969C
47FDF080: BFA80000 479F5F98 2 40284738 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
47FDF0A0: 0 46D27050 F F4240 495D6B70 E 46010000 46010000
47FDF0C0: 1 40055734 47FDF0C8 FFFFFFFF 0 46960000 0 210AC
47FDF0E0: 0 210AC 0 210A8 0 47A81A58 0 46959250
47FDF100: 0 0 0 0 0 46959250 0 46959254
47FDF120: 0 0 0 210A8 0 467A0000 0 47390000
47FDF140: 0 49452FA0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
47FDF160: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
47FDF180: FFFFFFFF FFFFFFFF 0 47380000 0 0 0 3040A801
47FDF1A0: FFFFFFFF A000F000 FFFFFFFF FFFFFFFF 0 47A819D0 FFFFFFFF FFFFFFFF
47FDF1C0: 0 40064A50 3400FF03 FFFFFFFF 0 1F308C49 FFFFFFFF CF025319
47FDF1E0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 0 42E1058C FFFFFFFF FFFFFFFF
47FDF200: FFFFFFFF
$0 : FFFFFFFF, AT : 46960000, v0 : 000210AC, v1 : 000210AC
a0 : 000210A8, a1 : 47A81A58, a2 : 46959250, a3 : 00000000
t0 : 00000000, t1 : 46959250, t2 : 46959254, t3 : 00000000
t4 : 000210A8, t5 : 467A0000, t6 : 47390000, t7 : 49452FA0
gp : FFFFFFFF, sp : 47A819D0, s8 : FFFFFFFF, ra : 40064A50
EPC : 42E1058C, ErrorEPC : FFFFFFFF, SREG : 3400FF03
MDLO : 1F308C49, MDHI : CF025319, BadVaddr : FFFFFFFF
---- Level 5 Interrupt stack (0x1134 bytes used, out of 0x2328 available) ----
intstacks[5]: base 0x47FDABB4 stack 0x47FDCED8 routine 0x4026CC64 count 0x1
size 0x2328 low 0x2328 desc 0x43FF1404
47FDCADC: 44463734 30453542 36413834 A000000 0 20 FFFFFFFF 0
47FDCAFC: FFFFFFFF 47FDCA9F 0 34303431 46463334 47FDCAAF 33E 47FDCAB7
47FDCB1C: 0 0 0 30 9 1 8 47FDCAD7
47FDCB3C: 0 0 0 20 46FB3B23 1 9 1
47FDCB5C: 46FB3B20 43DB0000 43FF969C 46FB3B20 46FB3B23 24 46FB3B20 43DC0000
47FDCB7C: 43DC0000 43DC0000 43FF1404 46D27144 417A00E4 0 40095384 43DBBA76
47FDCB9C: 47FDCBC4 47FDCBA0 47FDCED8 33 46FB3B20 43DC0000 400883C4 46D27144
47FDCBBC: 417A00E4 417A00E4 1 400 43DB0000 5 46FB3B20 47FDCADC
47FDCBDC: 47FDCEDC 2328 40056F60 32C 0 0 1 47FDCED8
47FDCBFC: 4026CC64 1 2328 2328 43FF1404 47FDCED8 4026CC64 1
47FDCC1C: 417A00E4 43DB0000 46FB3B20 A0001E89 46510000 46D27144 A0001E89 46010000
47FDCC3C: 1 40366F84 40057E58 0 1 A0001E89 1 31373A33
47FDCC5C: 363A3230 20495354 20576564 204E6F76 20313320 32303133 0 47FDCC17
47FDCC7C: 47FDCD00 0 0 30 0 1 8 8
47FDCC9C: 0 0 1 A000219D A000219D 46D20000 A0002141 0
47FDCCBC: A0001E89 46010000 0 0 4179FFD4 A00021B5 0 40057D38
47FDCCDC: 40057D38 0 1 46C6D348 40051070 47A974C8 467A0000 43DA59F0
47FDCCFC: FF0000 4D4 0 43DAE6FC 0 43DAE700 0 28
47FDCD1C: 0 1 467A0000 16 0 47FDCDA0 46010000 495D6C7C
47FDCD3C: 0 4600C650 400511F0 4600C650 417A00E4 47FDCD58 1C 31373A33
47FDCD5C: 363A3139 20495354 20576564 204E6F76 20313320 32303133 26CE0C FFFFFFFF
47FDCD7C: 8000 46D76380 F F 0 0 46010000 40055930
47FDCD9C: FFFFFFFF FFFFFFFF FFFFFFFF 0 46960000 0 0 0
47FDCDBC: 0 0 46D22BE0 0 0 0 0 0
47FDCDDC: 0 0 C 0 2EB2 0 2EB1 0
47FDCDFC: CE3 0 CE2 0 0 0 4000 0
47FDCE1C: 40000000 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
47FDCE3C: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
47FDCE5C: FFFFFFFF 0 8000000 0 2EB7 0 0 0
47FDCE7C: 0 FFFFFFFF FFFFFFFF 0 47FE5A40 FFFFFFFF FFFFFFFF 0
47FDCE9C: 40011564 3400F903 FFFFFFFF 0 401F964 FFFFFFFF F8CB9683 FFFFFFFF
47FDCEBC: FFFFFFFF FFFFFFFF FFFFFFFF 0 40055014 FFFFFFFF FFFFFFFF FFFFFFFF
$0 : FFFFFFFF, AT : 46960000, v0 : 00000000, v1 : 00000000
a0 : 46D22BE0, a1 : 00000000, a2 : 00000000, a3 : 00000000
t0 : 0000000C, t1 : 00002EB2, t2 : 00002EB1, t3 : 00000CE3
t4 : 00000CE2, t5 : 00000000, t6 : 00004000, t7 : 40000000
t8 : 08000000, t9 : 00002EB7, k0 : 00000000, k1 : 00000000
gp : FFFFFFFF, sp : 47FE5A40, s8 : FFFFFFFF, ra : 40011564
EPC : 40055014, ErrorEPC : FFFFFFFF, SREG : 3400F903
---- Level 6 Interrupt stack (base 0x0, size 0x0) is invalid ----
---- Level 7 Interrupt stack (0x1B4 bytes used, out of 0x2328 available) ----
intstacks[7]: base 0x47FD888C stack 0x47FDABB0 routine 0x40056820 count 0x42223
size 0x2328 low 0x2328 desc 0x43DAE7D0
47FDAA00: 0 1062CC 0 1062CC FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
47FDAA20: 0 107B08 0 107B08 FFFFFFFF FFFFFFFF 0 108890
47FDAA40: 28 48181FDE BFB00010 46010000 28 40056B48 FFFFFFFF FFFFFFFF
47FDAA60: FFFFFFFF FFFFFFFF 4005497C 28 42E11060 FFFFFFFF FFFFFFFF FFFFFFFF
47FDAA80: 0 46960000 0 46960000 0 43FF7450 0 47FDC740
47FDAAA0: 0 3028 0 46959254 0 46959250 0 0
47FDAAC0: 0 10888C 0 1 0 4600C650 0 3028
47FDAAE0: 0 3000 0 28 0 30 FFFFFFFF FFFFFFFF
47FDAB00: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
47FDAB20: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 0 47FDCAD8
47FDAB40: 0 1 0 8 0 0 FFFFFFFF FFFFFFFF
47FDAB60: 0 47FDCAB0 FFFFFFFF FFFFFFFF 0 4179F480 34008003 FFFFFFFF
47FDAB80: 0 0 0 F FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
47FDABA0: 0 4179F498 FFFFFFFF FFFFFFFF FFFFFFFF
$0 : FFFFFFFF, AT : 46960000, v0 : 00000000, v1 : 47FDCAD8
a0 : 47FDCADE, a1 : 00000000, a2 : 00000046, a3 : FFFFFFFE
t0 : 46FABEA4, t1 : 00000001, t2 : 00000001, t3 : 00000400
t4 : 00000008, t5 : 0000000A, t6 : 00000046, t7 : 46000000
t8 : 47FDCAD8, t9 : 00000001, k0 : 00000008, k1 : 00000000
gp : FFFFFFFF, sp : 47FDCAB0, s8 : FFFFFFFF, ra : 4179F480
EPC : 4179F498, ErrorEPC : FFFFFFFF, SREG : 34008003
MDLO : 00000000, MDHI : 0000000F, BadVaddr : FFFFFFFF
========= Register Memory Dump ================
Reg00($0): 0 [Not RAM Addr]
Reg01(AT): 0 [Not RAM Addr]
Reg02(v0): 0 [Not RAM Addr]
Reg03(v1): 0 [Not RAM Addr]
Reg04(a0): 0 [Not RAM Addr]
Reg05(a1): 0 [Not RAM Addr]
Reg06(a2): 0 [Not RAM Addr]
Reg07(a3): 0 [Not RAM Addr]
Reg08(t0): 0 [Not RAM Addr]
Reg09(t1): 0 [Not RAM Addr]
Reg10(t2): 0 [Not RAM Addr]
Reg11(t3): 0 [Not RAM Addr]
Reg12(t4): 0 [Not RAM Addr]
Reg13(t5): 0 [Not RAM Addr]
Reg14(t6): 0 [Not RAM Addr]
Reg15(t7): 0 [Not RAM Addr]
Reg16(s0): 0 [Not RAM Addr]
Reg17(s1): 0 [Not RAM Addr]
Reg18(s2): 0 [Not RAM Addr]
Reg19(s3): 0 [Not RAM Addr]
Reg20(s4): 0 [Not RAM Addr]
Reg21(s5): 0 [Not RAM Addr]
Reg22(s6): 0 [Not RAM Addr]
Reg23(s7): 0 [Not RAM Addr]
Reg24(t8): 0 [Not RAM Addr]
Reg25(t9): 0 [Not RAM Addr]
Reg26(k0): 0 [Not RAM Addr]
Reg27(k1): 0 [Not RAM Addr]
Reg28(gp): 0 [Not RAM Addr]
Reg29(sp): 0 [Not RAM Addr]
Reg30(s8): 0 [Not RAM Addr]
Reg31(ra): 0 [Not RAM Addr]
buffer check=0 sched_hc=0x0
========= Scheduler History Dump ======================
PID Exectime(ms) Caller PC Process Name
183 3484 0x0 HQF Shaper Background
116 4 0x41E42E24 IP ARP Retry Ager
183 100 0x4295B454 HQF Shaper Background
300 20 0x42E45344 PPP Events
183 20 0x4295B454 HQF Shaper Background
299 8 0x42773C3C PPP manager
184 4 0x429B3450 RBSCP Background
301 0 0x4233E9F0 Multilink PPP
41 8 0x417B9868 TTY Background
151 16 0x41B4D8BC CEF: IPv4 process
183 80 0x4295B454 HQF Shaper Background
227 0 0x40EFE2C4 FLEX DSP KEEPALIVE MAIN
311 12 0x42611AC8 NTP
226 4 0x40EFE750 FLEX DSPRM MAIN
257 4 0x40A4C078 Atheros LED Ctrol
183 40 0x4295B454 HQF Shaper Background
33 0 0x4180781C GraphIt
271 0 0x40BD67FC trunk conditioning supervisory
62 0 0x4069FD34 Netclock Background Proccess
20 4 0x411BC62C ARP Background
100 0 0x4096C56C Ethernet Timer CFM
128 0 0x42CAF4C8 SSS Feature Timer
42 4 0x40350ED4 Per-Second Jobs
Dumping Managed Timer Operation history [Next Entry(4)]
Index IPL Caller_pc Timer Operation
0 0 0x42163C30 0x4877C1A0 Managed Timer Initialized
1 0 0x42163C48 0x4877C1C0 Managed Timer Initialized
2 0 0x42163C60 0x4877C1E0 Managed Timer Initialized
3 0 0x42163C78 0x4877C200 Managed Timer Initialized
4 0 0x0 0x00000000 Empty Buffer
5 0 0x0 0x00000000 Empty Buffer
6 0 0x0 0x00000000 Empty Buffer
7 0 0x0 0x00000000 Empty Buffer
8 0 0x0 0x00000000 Empty Buffer
9 0 0x0 0x00000000 Empty Buffer
10 0 0x0 0x00000000 Empty Buffer
11 0 0x0 0x00000000 Empty Buffer
12 0 0x0 0x00000000 Empty Buffer
13 0 0x0 0x00000000 Empty Buffer
14 0 0x0 0x00000000 Empty Buffer
15 0 0x0 0x00000000 Empty Buffer
16 0 0x0 0x00000000 Empty Buffer
17 0 0x0 0x00000000 Empty Buffer
18 0 0x0 0x00000000 Empty Buffer
19 0 0x0 0x00000000 Empty Buffer
20 0 0x0 0x00000000 Empty Buffer
21 0 0x0 0x00000000 Empty Buffer
22 0 0x0 0x00000000 Empty Buffer
23 0 0x0 0x00000000 Empty Buffer
24 0 0x0 0x00000000 Empty Buffer
========= Data Inconsistency Errors =========
No data inconsistency errors have been recorded.
========= End of Crashinfo Collection ================
Router#sh flas
Router#sh flash:
-#- --length-- -----date/time------ path
1 55774568 May 10 2010 09:49:08 c2800nm-advipservicesk9-mz.124-20.T5.bin
2 2900 May 10 2010 10:00:24 cpconfig-2811.cfg
3 2324992 May 10 2010 10:00:42 cpexpress.tar
4 1038 May 10 2010 10:00:52 home.shtml
5 115712 May 10 2010 10:01:00 home.tar
6 1697952 May 10 2010 10:01:18 securedesktop-ios-3.1.1.45-k9.pkg
7 415956 May 10 2010 10:01:32 sslclient-win-1.1.4.176.pkg
8 53882 Nov 13 2013 07:11:32 crashinfo_20131113-071133
9 50832 Nov 13 2013 07:25:22 crashinfo_20131113-072522
10 50730 Nov 13 2013 07:34:06 crashinfo_20131113-073406
11 50829 Nov 13 2013 07:40:04 crashinfo_20131113-074004
12 52920 Nov 13 2013 07:54:54 crashinfo_20131113-075455
13 51140 Nov 13 2013 08:04:44 crashinfo_20131113-080445
14 50728 Nov 13 2013 08:10:58 crashinfo_20131113-081058
15 54650 Nov 13 2013 08:25:06 crashinfo_20131113-082507
16 50902 Nov 13 2013 08:37:26 crashinfo_20131113-083727
17 51021 Nov 13 2013 09:02:42 crashinfo_20131113-090242
18 50784 Nov 13 2013 09:09:38 crashinfo_20131113-090938
19 50924 Nov 13 2013 09:18:12 crashinfo_20131113-091813
20 50738 Nov 13 2013 09:24:12 crashinfo_20131113-092412
21 50969 Nov 13 2013 09:31:38 crashinfo_20131113-093138
22 50730 Nov 13 2013 09:40:54 crashinfo_20131113-094055
23 51440 Nov 13 2013 09:53:42 crashinfo_20131113-095343
24 50977 Nov 13 2013 10:15:18 crashinfo_20131113-101518
25 50469 Nov 13 2013 10:45:46 crashinfo_20131113-104545
26 50409 Nov 13 2013 11:02:00 crashinfo_20131113-110200
27 50587 Nov 13 2013 11:12:18 crashinfo_20131113-111218
28 50195 Nov 13 2013 11:46:14 crashinfo_20131113-114613
29 50105 Nov 13 2013 12:06:20 crashinfo_20131113-120620
67211264 bytes available (61526016 bytes used)
11-13-2013 04:36 AM
Thanks for posting the output. These lines of the output are among the most useful of what is posted
If this router is covered by a maintenance contract then you should open a case with Cisco TAC to further investigate the cause of the error. If your router is not under maintenance do you have access to another version of code for this router?
Rick
11-13-2013 04:39 AM
its look like: As it turns out, the memory is bad in this router.
You have HW failure related to SDRAM memory parity errors:
I suggest you replace the router SDRAM first, as DRAM memory failures are most often causes for such issues. Here is the guide on how to do that:
http://www.cisco.com/en/US/docs/routers/access/2800/hardware/installation/guide/10_hw.html#wp1056378
or
Contact your Local supplier for Cisco Devices & ask him to look into this Matter.
"SDRAM ECC Error" message means there is a problem with the memory on the router, probably its a parity error. If it happened only once, it can be considered a one-time issue. If it happened multiple times, you need to replace the memory module in the router. If that does not help, probably the router needs a replacement.
hope it helps.
Reagrds
Please rate helpful posts
