11-30-2017 01:10 PM - edited 03-05-2019 09:34 AM
I have a 2811 router and I can not get it to boot properly. I've been troubleshooting it for a few days now but haven't made any progress. I'll start with with I've tried so far and post the output from the commands I have tried.
The router was pulled off our rack after we upgraded to a new router. It has a Cisco 128Mb CF card. When I first booted, it went directly into rommon mode. The first thing I tried was the confreg 0x2142 command. After I power cycle the router it just boots back to the same prompt. I setup a TFTP server and tried copying the IOS but kept getting timeout errors. I tried different ethernet cables and both ports ethernet port on the router but no luck. I then tried the xmodem method and changed the serial baud rate 1152000. I left it running overnight and came back to a timeout error. I then found a spare 256MB Sandisk Compact Flash card and tried the TFTP and xmodem methods again but got the same error. I then bought a compact flash card reader and was able to read and format both cards. I copied the contents of the original CF card to my PC then formatted (tried both FAT and FAT32) and put a new IOS on it but it still would not boot. I then put the original files on the SanDisk CF card (tried both FAT and FAT32 again) but still get the same errors. I then found an old 4GB usb memory stick and formatted it then copied a new IOS to it but I can't seem to access the drive using the DIR command. I just ordered a new OEM Cisco 128MB CF card but it probably will not be here till next week. Any information or suggestions would be helpful. Below is the output from the console.
___________________________________________________________________________
System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
Initializing memory for ECC
c2811 platform with 524288 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
open(): Open Error = -66
boot: cannot open "flash:"
boot: cannot determine first executable file name on device "flash:"
Entering rommon> prompt after several failed attempts to boot an IOS image.
Please check your internal/external flash drives for the correct IOS image
and issue 'reset' at the rommon> prompt to re-try the boot process.
rommon 1 > confreg 0x2142
You must reset or power cycle for new config to take effect
rommon 2 >
rommon 1 > dev
Devices in device table:
id name
flash: compact flash
bootflash: boot flash
usbflash0: usbflash0
usbflash1: usbflash1
eprom: eprom
rommon 2 > dir flash:
dir: cannot open device "flash:"
rommon 3 > dir bootflash:
dir: cannot access device "bootflash:"
rommon 4 > dir usbflash0:
program load complete, entry point: 0x8000f000, size: 0x3d240
open(): Open Error = -1
dir: cannot open device "usbflash0:"
rommon 5 > dir usbflash1:
dir: cannot open device "usbflash1:"
rommon 6 > dir usbflash0:
rommon 7 > dir eprom:
dir: cannot access device "eprom:"
rommon 8 >
12-11-2017 10:12 PM
12-12-2017 09:44 AM
Below is the output as requested...
Compact Flash:not present
rommon 1 > dev
id name
eprom: eprom
rommon 3 > reset
rommon 1 > dir usbflash0:
rommon 2 >
12-12-2017 12:30 PM
12-12-2017 12:35 PM
Yes, it is the same USB memory stick I was using before. I have some other memory sticks but they're too big to be formatted in FAT. You had said in a previous post "The USB flash drive works but the IOS could be corrupt."Thank you for following up.
12-12-2017 12:40 PM
12-12-2017 01:24 PM
Well I checked the MD5 on the IOS files that I have but none of the MD5 checks match, so I'm assuming I've been downloading some bad files. This is an old router and I don't have a service contract with Cisco so I can't download anything from the website. I found a couple links stating that there is a legal method to download firmware images for free but I'm not sure it will work. I don't really have any other option so I'm going to give it a try...
https://serverfault.com/questions/286620/how-to-obtain-cisco-ios-firmware
12-12-2017 10:12 PM
Well, this will definitely cause the router not to boot the IOS.
12-13-2017 11:03 AM
I thought I would still be able to see the files on the CF card or USB stick with DIR command but I guess I was wrong.
I didn't have any luck getting the IOS image from Cisco support so I decided my best option is to just order another 2811 router that comes with the IOS and just copy the files onto another CF card. Thanks for all your help.
12-16-2017 11:42 AM
Alright, so I got my second 2811 router so I could get a valid IOS image. It boots up fine without a problem so I copied the contents of the CF card to another CF card and tried booting my other router but it is still stuck in rommon mode. I also tried copying the files to a USB stick but it still would not boot. I then tried booting with the CF card that came with the second router but it still will not boot. I copied the console output from the attempts and posted it below. Any help or suggestions would be appreciated. Thank you.
_____________________________________________________________________________
program load complete, entry point: 0x8000f000, size: 0x310cb04
Error : compressed image checksum is incorrect 0x0AE743EB
Expected a checksum of 0x35FD3FEB
*** System received a Software forced crash ***
signal= 0x17, code= 0x5, context= 0x80014e20
PC = 0x8000f0d4, Cause = 0x20, Status Reg = 0x3040a803
Error : compressed image checksum is incorrect 0x114A3C0B
Error : compressed image checksum is incorrect 0x1B7F43FB
Error : compressed image checksum is incorrect 0x1BF33BFB
Error : compressed image checksum is incorrect 0x1E9C3BEB
#Output from trying to boot from USB
rommon 1 > dev
id name
eprom: eprom
rommon 2 > boot usbflash0:
usbflash0: not present
rommon 3 > boot usbflash1:
*** TLB (Load/Fetch) Exception ***
Access address = 0x364
PC = 0x8003d878, Cause = 0x8, Status Reg = 0x3040a803
monitor: command "boot" aborted due to exception
rommon 4 > dir usbflash1:
Please reset before executing this command
rommon 5 > reset
rommon 1 > dir usbflash1:
monitor: command "dir" aborted due to exception
rommon 2 >
#Output from second router with same CF card
Self decompressing the image : ########################################################################################################################################################################################################################################################################################### [OK]
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0003E7 0X00474800 C2811 Mainboard
0X00264050 Onboard VPN
0X000021B8 Onboard USB
0X002C29F0 public buffer pools
0X00211000 public particle pools
TOTAL: 0X00BAE3F8
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 12Mb.
Using 2 percent iomem. [12Mb/512Mb]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(15)T9, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 28-Apr-09 13:09 by prod_rel_team
Image text-base: 0x400AF910, data-base: 0x437AF3A0
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Installed image archive
Cisco 2811 (revision 49.46) with 512000K/12288K bytes of memory.
Processor board ID FTX1528AH4Z
2 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
126976K bytes of ATA CompactFlash (Read/Write)
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]: n
Press RETURN to get started!
*Dec 16 19:17:16.091: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Initialized
*Dec 16 19:17:16.099: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Enabled
*Dec 16 19:17:17.795: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Dec 16 19:17:17.795: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
*Dec 16 19:17:17.795: %LINK-3-UPDOWN: Interface FastEthernet0/1, changed state to up
*Dec 16 19:17:17.795: %LINEPROTO-5-UPDOWN: Line protocol on Interface IPv6-mpls, changed state to up
*Dec 16 19:17:19.151: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to down
*Dec 16 19:17:19.151: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to down
*Dec 16 19:18:08.223: %LINK-5-CHANGED: Interface FastEthernet0/0, changed state to administratively down
*Dec 16 19:18:08.227: %LINK-5-CHANGED: Interface FastEthernet0/1, changed state to administrativel
Router>
Routey down
*Dec 16 19:18:09.147: %IP-5-WEBINST_KILL: Terminating DNS process
*Dec 16 19:18:15.675: %SYS-5-RESTART: System restarted --
*Dec 16 19:18:15.679: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
*Dec 16 19:18:15.907: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Dec 16 19:18:15.907: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Dec 16 19:18:15.907: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFFr>
Router>
#Output from trying to boot from USB on second router
rommon 1 > dev
id name
eprom: eprom
rommon 2 > dir usbflash0:
rommon 3 > dir usbflash1:
rommon 4 > boot usbflash0:
Please reset before booting
rommon 5 > reset
rommon 1 > boot usbflash0:
rommon 2 > boot usbflash1:
rommon 3 >
12-16-2017 06:54 PM
12-18-2017 10:00 AM
Below is the output from the set command.
rommon 1 > set
PS1=rommon ! >
FE_PORT=0
?=0
RET_2_RTS=16:27:26 UTC Thu Sep 2 2010
WARM_REBOOT=FALSE
RELOAD_TYPE=1
BSI=0
RET_2_RCALTS=
RANDOM_NUM=1009613081
rommon 2 >
12-18-2017 12:53 PM
12-18-2017 01:52 PM
Yeah, I had came to same conclusion that the CF card reader was bad. I have 2 CF cards that work in the other router but not on the old one. Since I figured the CF reader was bad and the USB stick was incompatible, I did some research into getting a different USB stick to boot. I came across this link, https://uwnthesis.wordpress.com/2015/08/31/how-to-convert-a-usb-into-fat-on-windows-7-for-plc-cisco-ios-usb/ , and I was able to get the newer router to boot off a 16GB USB stick but not on the old router. Below is the output from both routers booting off USB. I have the original files that were on the CF card from the old router, which is a different IOS than what came on the new router. I copied the both sets of files to the USB stick, not at the same time but 2 different attempts, but was still unable to get it to boot on the old router.
New Router
Directory of usbflash1:
14 32244652 -rw- c2800nm-ipbase-mz.150-1.M3.bin
0 0 -rw- 2GB
2 0 drw- System Volume Information
5 527849 -rw- 128MB.SDF
507 2900 -rw- cpconfig-2811.cfg
508 2938880 -rw- cpexpress.tar
553 1038 -rw- home.shtml
554 122880 -rw- HOME.TAR
556 1697952 -rw- securedesktop-ios-3.1.1.45-k9.pkg
582 415956 -rw- sslclient-win-1.1.4.176.pkg
program load complete, entry point: 0x8000f000, size: 0x1ec01e4
Self decompressing the image : ################################################################################################################################################################################################# [OK]
ID MEMORY_REQ TYPE
TOTAL: 0X0094A3A8
Rounded IOMEM up to: 10Mb.
Using 1 percent iomem. [10Mb/512Mb]
cisco Systems, Inc.
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 15.0(1)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sun 18-Jul-10 02:24 by prod_rel_team
Image text-base: 0x40016630, data-base: 0x42466D60
Cisco 2811 (revision 49.46) with 514048K/10240K bytes of memory.
3059696K bytes of USB Flash usbflash1 (Read/Write)
% Crashinfo may not be recovered at flash:crashinfo
% This file system device reports an error
*Dec 18 21:02:29.607: %SW_VLAN-4-IFS_FAILURE: VLAN manager encountered file operation error: call = ifs_open/read / code = 3588 (No device available)
/ bytes transfered = 0
*Dec 18 21:02:29.623: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
*Dec 18 21:02:29.623: %LINK-3-UPDOWN: Interface FastEthernet0/1, changed state to up
*Dec 18 21:02:29.971: %USB_HOST_STACK-6-USB_DEVICE_CONNECTED: A Full speed USB device has been inserted in port 1.
*Dec 18 21:02:30.203: %USB_HOST_STACK-6-USB_DEVICE_DISCONNECTED: A USB device has been removed from port 0.
*Dec 18 21:02:30.891: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to down
*Dec 18 21:02:30.891: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to down
*Dec 18 21:02:30.899: %USBFLASH-5-CHANGE: usbflash1 has been inserted!
*Dec 18 21:03:25.547: %LINK-5-CHANGED: Interface FastEthernet0/0, changed state to administratively down
*Dec 18 21:03:25.547: %LINK-5-CHANGED: Interface FastEthernet0/1, changed state to administratively down
*Dec 18 21:03:28.143: %IP-5-WEBINST_KILL: Terminating DNS process
*Dec 18 21:03:29.563: %SYS-5-RESTART: System restarted --
*Dec 18 21:03:29.575: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
Router>
Router>
Router>
Router>
Router>
Router>
Router>
Router>
Router>
96 51432612 -rw- c2800nm-advipservicesk9-mz.124-15.T9.bin
0 0 -rw- 2GB
5 2900 -rw- cpconfig-2811.cfg
6 2941440 -rw- cpexpress.tar
51 1038 -rw- home.shtml
52 115712 -rw- HOME.TAR
54 1697952 -rw- securedesktop-ios-3.1.1.45-k9.pkg
80 415956 -rw- sslclient-win-1.1.4.176.pkg
87 527849 -rw- 128MB.SDF
ID MEMORY_REQ TYPE
TOTAL: 0X00BAE3F8
cisco Systems, Inc.
Image text-base: 0x400AF910, data-base: 0x437A21F0
export@cisco.com.
*Dec 18 21:08:35.047: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Initialized
*Dec 18 21:08:35.055: %VPN_HW-6-INFO_LOC: Crypto engine: onboard 0 State changed to: Enabled
*Dec 18 21:08:36.727: %USB_HOST_STACK-6-USB_DEVICE_CONNECTED: A Full speed USB device has been inserted in port 1.
*Dec 18 21:08:36.955: %USB_HOST_STACK-6-USB_DEVICE_DISCONNECTED: A USB device has been removed from port 0.
*Dec 18 21:08:37.083: %SW_VLAN-4-IFS_FAILURE: VLAN manager encountered file operation error: call = ifs_open/read / code = 3588 (No device available)
*Dec 18 21:08:37.095: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Dec 18 21:08:37.099: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
*Dec 18 21:08:37.099: %LINK-3-UPDOWN: Interface FastEthernet0/1, changed state to up
*Dec 18 21:08:37.099: %LINEPROTO-5-UPDOWN: Line protocol on Interface IPv6-mpls, changed state to up
*Dec 18 21:08:38.099: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to down
*Dec 18 21:08:38.099: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to down
*Dec 18 21:08:42.647: fnu1362ControlTransfer Control Transfer did not complete! 1
*Dec 18 21:08:42.647: fnu1362ControlTransfer speed: 0x2, pipe: 0x80000080, status: 0x31
*Dec 18 21:08:42.647: fnu1362ControlTransfer, bmRequestType: 0x80, byRequest: 0x6, wValue: 0x100, wIndex: 0x0, wLength: 0x8
*Dec 18 21:08:42.655: %USB_HOST_STACK-5-USB_ENUM_FAIL_GETDESCR: Failed to enumerate a USB device as not able to read the device's description.
*Dec 18 21:09:49.083: %IP-5-WEBINST_KILL: Terminating DNS process
*Dec 18 21:09:49.435: %LINK-5-CHANGED: Interface FastEthernet0/0, changed state to administratively down
*Dec 18 21:09:49.435: %LINK-5-CHANGED: Interface FastEthernet0/1, changed state to administratively down
*Dec 18 21:09:50.543: %SYS-5-RESTART: System restarted --
*Dec 18 21:09:50.547: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
*Dec 18 21:09:50.771: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Dec 18 21:09:50.775: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Dec 18 21:09:50.775: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
Router>
0 0 -rw- 2GB
ID MEMORY_REQ TYPE
TOTAL: 0X0094A3A8
cisco Systems, Inc.
Router>
Router>
Router>
Router>
Router>
Router>
Router>
Router>
Router>
0 0 -rw- 2GB
ID MEMORY_REQ TYPE
TOTAL: 0X00BAE3F8
cisco Systems, Inc.
export@cisco.com.
Router>
Old router
0 0 -rw- 2GB
Error : compressed image checksum is incorrect 0x18C54FEB
0 0 -rw- 2GB
Error : compressed image checksum is incorrect 0x1BD7380B
rommon 1 >
12-18-2017 02:19 PM
Would the information on the link below allow me to get past the checksum error?
12-27-2017 11:46 AM
Can anyone offer me some suggestions on how to fix the issue with the router?
