Cisco 2811 System returned to ROM by error - a Software forced crash
Hi, i have a trouble in a Router Cisco 2811.
This Router suddenly reloads, What might be the issue?. i have attached the output of Show Stack Command in a TXT file.
Please Help Me
i saw an strange log in the Show Stack Output:
000018: *Jul 18 11:21:02.747: %SYS-5-CONFIG_I: Configured from memory by consoleCMD: 'access-list 199 permit icmp host 10.10.10.10 host 20.20.20.20' 11:21:03 COL Sat Jul 18 2015
000019: *Jul 18 11:21:03.063: %PARSER-5-CFGLOG_LOGGEDCMD: User:console  logged command:access-list 199 permit icmp host 10.10.10.10 host 20.20.20.20CMD: 'crypto map NiStTeSt1 10 ipsec-manual' 11:21:03 COL Sat Jul 18 2015
000020: *Jul 18 11:21:03.075: %PARSER-5-CFGLOG_LOGGEDCMD: User:console  logged command:crypto map NiStTeSt1 10 ipsec-manual CMD: 'match address 199
000021: *Jul 18 11:21:03.079: %PARSER-5-CFGLOG_LOGGEDCMD: User:console  logged command:match address 199
CMD: 'set peer 20.20.20.20
000022: *Jul 18 11:21:03.083: %PARSER-5-CFGLOG_LOGGEDCMD: User:console  logged command:set peer 20.20.20.20
CMD: 'exit' 11:21:03 COL Sat Jul 18 2015
000023: *Jul 18 11:21:03.083: %PARSER-5-CFGLOG_LOGGEDCMD: User:console  logged command:exit CMD: 'no access-list 199' 11:21:03 COL Sat Jul 18 2015
000024: *Jul 18 11:21:03.107: %PARSER-5-CFGLOG_LOGGEDCMD: User:console  logged command:no access-list 199CMD: 'no crypto map NiStTeSt1' 11:21:03 COL Sat Jul 18 2015
000025: *Jul 18 11:21:03.123: %PARSER-5-CFGLOG_LOGGEDCMD: User:console  logged command:no crypto map NiStTeSt1
000026: *Jul 18 11:21:03.695: %SYS-5-RESTART: System restarted --
and later appears the following Log and restart again:
000047: .Jul 18 11:30:13.485: %SYS-6-STACKLOW: Stack for process SSH Process running low, 0/12000
%Software-forced reload
 11:30:13 COL Sat Jul 18 2015: Breakpoint exception, CPU signal 23, PC = 0x40050188
"T" train IOS is known as the "technology" train.  Some of us call it "trouble".  The objective of the "T" train is for new features to be introduced to the IOS.  New "features" also means bugs, which can vary from configurations to configurations and one of the main causes for appliance crashes.
Generally speaking, the consensus among some of us is this:  If the router(s) is/are running "T" train, then don't be surprised to see the appliance(s) crash very often.
The "M" train is known for stability purposes and this the reason why I'm recommending you try loading.
7 Replies 7
Leo Laohoo
Can you post the complete output to the command "sh version"?
Of course, look at this attached file.
Thank You so much Leo
Ok, just as suspected.  The IOS is a "T" train.  Try upgrading the IOS into something more stable, like an "M" train.
ok, i will upgrade the IOS, can you tell me what happen, why does this router reload?, Maybe become to increase the CPU usage, become to run any process?... please, i jus want to know what can happen here.
Thank You So Much
thank you So Much..
If you can Explain Me in more details what could Happen here about that bug, i will thank you a lot.
I'm no Cisco staff.  So decoding Tracebacks and system crashes is going to be the job of Cisco TAC.
