cisco 2821 after configuring extended ACL getting reloaded
lerner cisco
Hi ,
I got cisco 2821 router with image code :flash:c2800nm-ipbase-mz.124-15.T.bin"  the behavior is after configuring extended acl , it is getting reloaded
any one come across this behavior or is this kind of IOS bug , please suggest
Lerner
Ruben Cocheno
it´s really strange, did you upgrade the router by the way?If yes does it has the requirements to load that code? Post here your config and what particular access-list you setup
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
