cisco 2821 cannot remove etherchannel
robinhall1
I have a cisco 2821 that I attempted to set up an etherchannel in the past. I was trying to do it again and i kept getting an error that the VLANs do not match. Upon looking at the running config there was a stale config for an etherchannel. When trying to set up the new etherchannel it created a duplicate etherchannel 1. I can remove the duplicate one but I cannot get rid of the original one no matter what I do. I have tried duplicating the config of the stale etherchannel to all of the interfaces that I have tried to add to it. Currently I have removed any config related to the channel-group on all the interfaces and this is what I get with these commands.
Show etherchannel summary:
<code>
#sh etherchannel summary
Flags: D - down P - in port-channel
I - stand-alone s - suspended
R - Layer3 S - Layer2
U - in use
Group Port-channel Ports
1 Po1(SD)
1 Po1(SD)
</code>
Show running config:
<code>
#sh run | s channe
interface Port-channel1
switchport trunk native vlan 5
switchport trunk allowed vlan 1,200,300,1002-1005
switchport mode trunk
no ip address
</code>
If I try to do 'show running-config interface port-channel1' I get the following error:
<code>
#sh running-config int port-channel 1
% Invalid input detected at '^' marker.
</code>
I get the above error no matter what command I try to use to edit view or change this. I have tried adding the config of the stale port-channel to all of the interfaces verbatem prior to re-adding the channel-group 1 mode on caommand but that does not help. I get this config:
<code>
shutdown
hold-queue 0 in
no ip address
</code>
Yes unfortunately it could be a bug, I had a similar situation with an EIGRP stub on a Cisco 4948 a long time ago, it was impossible to deleted or overwrite until I remove the config from zero.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
11 Replies 11
Julio E. Moisa
Try with
show run interface po1
To edit the port-channel interface you should use:
enable
conf t
interface po1
now you can modify it.
No matter how I try to show run for the port-channel I get the above error pointing tot the 1 like it does not exist.
It could be because your credentials are not allow any change, do you have privilege 15?
Also, the following message is related to a bug, you could need to upgrade the IOS
-Traceback= 43C5E724z 403B2910z 403E6B7Cz 403E6EA0z 402C42F4z 41E6F1DCz 41E5AEDCz 41E5BA84z 41E6BF34z 44AF41ACz 44AEA4E8z 43E5E6E0z 43E5E6C4z
Yes, this is my router. I have complete permissions. The issue is there is a stale config for an etherchannel that does not exist. I cannot change, delete or anything to this stale config. When I try to recreate the channel-group it actually creates a duplicate port-channel 1. I can work with this one, but if I try to make any changes to it, it says I cannot change the port type. I can shut it down and remove it, but the stale config stays in there. I cannot create any other channel groups either.
Thank you, that is not a normal situation, have you tried upgrade the IOS, or removing the config and reload but previously getting a backup the config.
The IOS is the most current I can get for it. When i get a chance I was going to try to reseat the card to see if that made a difference. Probably doing a write erase and reloading hte config would be the best bet. I will try that before reseating the card. I was hoping that someone else ran into a similar issue and new some way to fix at a lower level before I start doing the drastic stuff.
in addition to Julio's post, try to default all the member interfaces and the port channel interface:
2821(config)#default interface x
That said, the port channel config doesn't look right, as you are not allowing the native VLAN:
Add the native VLAN to the allowed list:
switchport trunk allowed vlan 1,5,200,300,1002-1005
I cannot make any changes to the port-channel config. I will try to default all of the ports that I have had included with the channel-group.
robinhall1
Some more information. I add the command 'channel-group 1 mode on' to the interfaces for the channel-group and I get this error in the logs:
Aug 15 07:15:15.765: %SNMP-3-DVR_DUP_REGN_ERR: Attempt for dupe regn with SNMP by driver having ifIndex 256 and ifDescr Port-channel1
robinhall1
This was resolved by doing a write erase and pushing back the config minus the stale etherchannel config.
