Cisco 2821 Router
saroj pradhan
can some one provide me  urgent support .
i have  cisco 2821 router  in my  network  and for the requiremet i have  installed  one  dual port HWIC-2FE  card .
in the show int and  sh ip int br   command  it is  not showing the newly  installed  FE but  in the sh diag  the following  showing.
My Router has the version details below.
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(11)XW9, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Sat 09-Aug-08 16:51 by prod_rel_team
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
        WIC Slot 2:
        2 Port FE HWIC
        WIC module not supported/disabled in this slot
        Hardware Revision        : 2.0
        Top Assy. Part Number    : 800-33018-01
        Part Number              : 73-12949-01
        Board Revision           : A0
        Deviation Number         : 0
        Fab Version              : 03
        PCB Serial Number        : FOC15372RF7
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : HWIC-2FE
        Version Identifier       : V02
        CLEI Code                : COUIAFUCAB
        Base MAC Address         : 7081.0575.845f
        MAC Address block size   : 2
        Connector Type           : 01
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF 40 05 3B 41 02 00 C0 46 03 20 00 80 FA 01
          0x10: 82 49 32 95 01 42 41 30 88 00 00 00 00 02 03 C1
          0x20: 8B 46 4F 43 31 35 33 37 32 52 46 37 03 00 81 00
          0x30: 00 00 00 04 00 CB 92 48 57 49 43 2D 32 46 45 20
          0x40: 20 20 20 20 20 20 20 20 20 89 56 30 32 20 D9 02
          0x50: 40 C1 C6 8A 43 4F 55 49 41 46 55 43 41 42 CF 06
          0x60: 70 81 05 75 84 5F 43 00 02 05 01 FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
please advice to bring the interface  UP.
Saroj
16 Replies 16
I have also done Earlier with my L3 SWITCH.
Still I want to know what is next if the Router reload before the new Image download on the Router.
Please provide guide line to perform.
saroj
If the router does reload before the new image is loaded then it will not be able to do a normal boot and will boot into rommon. From rommon you will need to load an image into flash. You may be able to use tftpdnld from rommon or you may need to use xmodem. If you have a local connection to the router from your PC this is not such a bit deal. If you are remote from the router then you will need to go to where the router is located.
Rick
Rick
