Nat issue? 887VAM-W
Hi.
I'm trying to configure a Cisco 887VAM-W router. The unit is connected to a ADSL WAN, and have two VLAN/WAN, one for public use and one the also connected to a corporate network via EZVpn. Everything worked fine for a while, untill I restarted the router and moved it.
Now, the router seems to boot just fine, it connects to the ADSL connection, get an IP adress on the ATM interface and connects to VON tunnel goes up. The problem is that non of the localy connected devices get IP-adresses or are abel to access the internet or communicate with anything on the other side of the VPN tunnel. The router itself can communicate with devices over the VPN tunnel and I'm abel to access the router from the corporate network over the VPN connection.
I'm pretty sure that I saved the configuration before I cold booted the router, but since it dosen't work as expected any more I'm guessing that something is missing, but I can't figure out what. I have also noticed that the NVI0 interface never goes up, it stays down both link and administrativly.
I current configuration is pasted bellow. The only diference right now is that I have removed the following access-lists bindings:
From ATM0.1 - ip access-group 102 in
From VLAN 1 - ip access-group 101 in
From VLAN 6 - ip access-group 103 in
Any ideas?
Best regards,
Johan Christensson
------- CONFIG START -------
version 15.2
hostname ISR01-xxx-xxx-xxx-SE
boot-start-marker
boot system flash:/c800-universalk9-mz.SPA.152-2.T.bin
boot-end-marker
enable secret 5 xxx
no aaa new-model
clock timezone Berlin 1 0
clock summer-time Berlin date Mar 30 2003 2:00 Oct 26 2003 3:00
crypto pki trustpoint TP-self-signed-xxxx
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-xxxx
revocation-check none
rsakeypair TP-self-signed-xxxx
crypto pki certificate chain TP-self-signed-xxxx
certificate self-signed 01
  xxxx
        quit
ip auth-proxy max-login-attempts 5
ip admission max-login-attempts 5
ip dhcp excluded-address 192.168.10.1 192.168.10.99
ip dhcp excluded-address 192.168.10.200 192.168.10.254
ip dhcp excluded-address 172.18.7.65 172.18.7.96
ip dhcp pool HomeNetDHCPPool
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 85.235.0.10
domain-name homenet.local
ip dhcp pool InsideDHCPPool
network 172.18.7.64 255.255.255.192
domain-name manhattan.local
default-router 172.18.7.65
dns-server 172.16.20.12 172.16.20.13
ip domain lookup source-interface Vlan1
ip domain name xxx.local
ip name-server 172.16.20.12
ip name-server 172.16.20.13
ip cef
license udi pid C887VAM-W-E-K9 sn Fxxxx
username xxx-xxx-xxx privilege 15 password 0 xxxx
controller VDSL 0
firmware filename flash:/vdsl.bin-A2pv6C035d_d23j
ip ssh version 2
crypto ipsec client ezvpn xxxx
connect auto
group xxx-xxx-xxx key xxx
mode network-extension
peer xxx.xxx.xxx.xxx
virtual-interface 1
username xxx-xxx-xxx-User password xxx
xauth userid mode local
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
ip address dhcp
ip nat outside
ip virtual-reassembly in
atm route-bridged ip
pvc 8/35
  encapsulation aal5snap
interface Ethernet0
no ip address
shutdown
interface FastEthernet0
switchport access vlan 6
no ip address
spanning-tree portfast
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Virtual-Template1 type tunnel
no ip address
tunnel mode ipsec ipv4
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
switchport mode trunk
no ip address
interface wlan-ap0
description Embedded Service module interface to manage the embedded AP
ip address 10.0.0.1 255.255.255.0
interface Vlan1
ip address 172.18.7.65 255.255.255.192
ip nat inside
crypto ipsec client ezvpn xxxx inside
interface Vlan6
ip address 192.168.10.1 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
ip http secure-server
ip nat inside source list inside_NAT_outside interface ATM0.1 overload
ip access-list extended inside_NAT_outside
deny   ip 172.18.7.64 0.0.0.63 172.18.7.64 0.0.0.63
deny   ip 192.168.10.0 0.0.0.255 192.168.10.0 0.0.0.255
permit ip 172.18.7.64 0.0.0.63 any
permit ip 192.168.10.0 0.0.0.255 any
access-list 100 permit ip host xxx.xxx.xxx.xxx any
access-list 100 permit ip 172.16.52.0 0.0.0.255 any
access-list 100 permit ip 172.18.7.64 0.0.0.63 any
access-list 101 permit tcp 172.16.52.0 0.0.0.255 host 172.18.7.65 eq 22
access-list 101 permit tcp 172.18.7.64 0.0.0.63 host 172.18.7.65 eq 22
access-list 101 permit tcp 172.16.52.0 0.0.0.255 host 172.18.7.65 eq 443
access-list 101 permit tcp 172.18.7.64 0.0.0.63 host 172.18.7.65 eq 443
access-list 101 permit tcp 172.16.52.0 0.0.0.255 host 172.18.7.65 eq cmd
access-list 101 permit tcp 172.18.7.64 0.0.0.63 host 172.18.7.65 eq cmd
access-list 101 deny   tcp any host 172.18.7.65 eq telnet
access-list 101 deny   tcp any host 172.18.7.65 eq 22
access-list 101 deny   tcp any host 172.18.7.65 eq www
access-list 101 deny   tcp any host 172.18.7.65 eq 443
access-list 101 deny   tcp any host 172.18.7.65 eq cmd
access-list 101 deny   udp any host 172.18.7.65 eq snmp
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 permit udp host xxx.xxx.xxx.xxx any eq 10000
access-list 102 permit udp host xxx.xxx.xxx.xxx any eq non500-isakmp
access-list 102 permit udp host xxx.xxx.xxx.xxx any eq isakmp
access-list 102 permit esp host xxx.xxx.xxx.xxx any
access-list 102 permit ahp host xxx.xxx.xxx.xxx any
access-list 102 permit udp host 172.16.20.13 eq domain any
access-list 102 permit udp host 172.16.20.12 eq domain any
access-list 102 permit tcp host xxx.xxx.xxx.xxx any eq 22
access-list 102 permit icmp host xxx.xxx.xxx.xxx any
access-list 102 deny   ip 172.18.7.64 0.0.0.63 any
access-list 102 permit udp any eq bootps any eq bootpc
access-list 102 permit icmp any any echo-reply
access-list 102 permit icmp any any time-exceeded
access-list 102 permit icmp any any unreachable
access-list 102 deny   ip 10.0.0.0 0.255.255.255 any
access-list 102 deny   ip 172.16.0.0 0.15.255.255 any
access-list 102 deny   ip 192.168.0.0 0.0.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip any any log
access-list 103 deny   ip 192.168.10.0 0.0.0.255 172.18.7.64 0.0.0.63
access-list 103 permit ip any any
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line vty 0 4
session-timeout 60
access-class 100 in
login local
transport preferred ssh
transport input ssh
scheduler allocate 20000 1000
sntp server 172.16.20.12
sntp server 172.16.20.13
sntp source-interface Vlan1
end
------- CONFIG END ------
No one that have any tips?
Almost all of the interfaces have the "status"  Internet protocol processing disabled. Any clue to why?
/Johan Ch
I don't have any idea why, but I got one of the teo routers working again. I formated all the flash: drives and retyped the configuration, and so far, everything seems to work just fine.
Will try to preform the same thing on the other one tomorrow.
/Johan Christensson
