Cisco 2901 router Throughput
Rickey369
What is the throughput of the Cisco 2901 router.  Can i have 1Gbps internet connection to this. Will this router support this speed as a Internet CE router ?
rick
dbeattie
The 2901 will not support a 1Gbps traffic flow rate (by quite a long way). For that you would need a 4431 (with performance license), 4451 or ASR920. If you want to take a full BGP table you would need and ASR1001x.
Hope this helps
Dave
mkazam001
Level 3
Level 3
