Cisco 2901 Unable to ping domain names
hirani89
I am unable to ping domain names like google.com. I can however ping 142.251.46.174.
Here is my config.
version 15.7
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp excluded-address 10.1.1.1 10.1.1.100
ip dhcp pool HOME
 import all
 network 10.1.1.0 255.255.255.0
 default-router 10.1.1.1
 dns-server 1.1.1.1 1.0.0.1
no ip domain lookup
ip domain name home.local
ip cef
no ipv6 cef
voice-card 0
license udi pid CISCO2901/K9 sn FGL153725V9
license boot module c2900 technology-package datak9
hw-module ism 0
hw-module pvdm 0/0
redundancy
interface Loopback100
 description hairpin
 ip address 169.254.255.254 255.255.255.255
 ip nat inside
 ip virtual-reassembly in
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 description -Ethernet WAN-
 ip address 14.211.43.146 255.255.255.252
 no ip redirects
 ip nat outside
 ip nat enable
 duplex auto
 speed auto
interface ISM0/0
 no ip address
 shutdown
 service-module fail-open
interface GigabitEthernet0/1
 ip address 10.1.1.1 255.255.255.0
 no ip redirects
 ip nat outside
 ip nat enable
 shutdown
 duplex auto
 speed auto
interface ISM0/1
 no ip address
interface Vlan1
 no ip address
ip default-gateway 14.211.43.145
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat source list NAT interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 14.211.43.145
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip access-list extended NAT
 deny   ip 10.1.1.0 0.0.0.255 10.1.1.0 0.0.0.255
ip access-list extended NatPin
 permit ip 10.1.1.0 0.0.0.255 host 10.1.1.100
ipv6 ioam timestamp
route-map NAT_PBR permit 10
 set interface Loopback100
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
gatekeeper
 shutdown
 vstack
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line 67
 no exec
 stopbits 1
line vty 0 4
 login
 transport input none
scheduler allocate 20000 1000
ntp server 34.208.249.133
end
Mark Elsen
          - You can not ping domain names only 'dedicated resolvable  hosts' ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hello
Try the following amendments and test again:
no int loopback0
no route-map NAT_PBR permit 10
no ip access-list extended NatPin
no ip access-list extended NAT
no ip default-gateway 14.211.43.145
ip dhcp pool HOME
no dns-server 1.1.1.1 1.0.0.1
dns-server 10.1.1.1
no ip nat enable
no ip nat enable
ip nat inside
no shutdown
permit ip 10.1.1.0 0.0.0.255 any
Kind Regards
Paul
pieterh
no ip domain lookup
ip cef
no ipv6 cef
your switch cannot perform DNS lookups because this is disabled and no name-servers are configured
ip dhcp pool HOME
 import all
your DHCP clients are querying 1.1.1.1 or 1.0.0.1 as DNS server
are you sure a DNS server is running on 1.1.1.1 or 1.0.0.1 ?
try 8.8.8.8 as DNS server
