Cisco 2911 IOS 15.7 - Cannot access the router via SSH from the local switch
I have set up SSH on the switch and the router; I can SSH from the router to the switch but not from the switch to the router. Any suggestions?
This is the message I get when trying to SSH to the router   [Connection to 192.168.0.5 aborted: error status 0]
The following is the sh run command on the router:
R1#sh run
Building configuration...
Current configuration : 1657 bytes
version 15.7
hostname R1
boot-start-marker
boot-end-marker
enable password Admin1
no aaa new-model
ip domain name odari.homemadelab.com
ip cef
no ipv6 cef
voice-card 0
vxml logging-tag
license udi pid CISCO2911/K9 sn FTX1543AH6P
hw-module pvdm 0/0
username cisco password 0 admin
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
description Link-to-SW3
ip address 192.168.0.5 255.255.255.128
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0/2
description Link-to-SW4
no ip address
duplex auto
speed auto
interface Serial0/0/0
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip ssh version 2
ip ssh client algorithm encryption 3des-cbc
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 3
login local
transport input ssh
transport output ssh
line vty 4
login
transport input none
scheduler allocate 20000 1000
end
Hello
The line configuration looks okay so if this hasnt already been suggested try a rsa key regeneration on the switch and test again.
switch:
crypto key zerosize
crypto key generate rsa label switch general-keys modulus 2048
ip ssh version 2
Kind Regards
Paul
9 Replies 9
Francesco Molino
What is your switch model and IOS version?
Can you run show ip ssh on both devices please?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
SW1#sh ver
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 15.0(2)SE11, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Sat 19-Aug-17 09:28 by prod_rel_team
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
SW1 uptime is 13 minutes
System image file is "flash:/c3750-ipservicesk9-mz.150-2.SE11/c3750-ipservicesk9-mz.150-2.SE11.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750G-48PS (PowerPC405) processor (revision C0) with 131072K bytes of memory.
Processor board ID FOC0916U14W
Last reset from power-on
2 Virtual Ethernet interfaces
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:15:62:55:33:00
Motherboard assembly number : 73-9365-08
Power supply part number : 341-0108-02
Motherboard serial number : FOC09343S9H
Power supply serial number : DCA09260MDP
Model revision number : C0
Motherboard revision number : A0
Model number : WS-C3750G-48PS-E
System serial number : FOC0916U14W
SFP Module assembly part number : 73-7757-03
SFP Module revision Number : A0
SFP Module serial number : CAT093108DF
Top Assembly Part Number : 800-26344-02
Top Assembly Revision Number : A0
Version ID : 02
CLEI Code Number : CNMWM00ARB
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
* 1 52 WS-C3750G-48PS 15.0(2)SE11 C3750-IPSERVICESK9-M
Configuration register is 0xF
Thanks for info, it's helps me.
Hello
This is what I get when trying to SSH to the Switch from the router
R1#ssh -l cisco 192.168.0.1
%SSH: CBC Ciphers got moved out of default config. Please configure ciphers as required(to match peer ciphers)
[Connection to 192.168.0.1 aborted: error status 0]
So is it from switch to rtr or rtr to switch or either way?
On the siwtch is ssh allowed egress and can you ping the rtr from it?
line vty 0 4
Kind Regards
Paul
I will post the sh run info soon.
Hello
switch:
crypto key zerosize
ip ssh version 2
Kind Regards
Paul
R1#sh ip ssh
SSH Enabled - version 2.0
Authentication methods:publickey,keyboard-interactive,password
Authentication Publickey Algorithms:x509v3-ssh-rsa,ssh-rsa
Hostkey Algorithms:x509v3-ssh-rsa,ssh-rsa
Encryption Algorithms:aes128-ctr,aes192-ctr,aes256-ctr
MAC Algorithms:hmac-sha2-256,hmac-sha2-512,hmac-sha1,hmac-sha1-96
KEX Algorithms:diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1
Authentication timeout: 120 secs; Authentication retries: 3
Minimum expected Diffie Hellman key size : 2048 bits
IOS Keys in SECSH format(ssh-rsa, base64 encoded): R1.homemadelab
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAgQCezbfyLO2QimMSIF5pCIPNea0PrwCT5QhRyqLb+q2M
X/S43YBNka793s2XbhrYNah8LfzvXpApRbMYQZsKJTXci4VhOho4BjbuZ5v10AQGbqqmD0cHB9RtzFlW
knzFam+wJEkCLk/91kqIi9suPOlQrsgUPk2EGP4Y2vrMI5obIQ==
SW1#sh ip ssh
Minimum expected Diffie Hellman key size : 1024 bits
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAAAgQDFnejquktVs4GZz2jGunrPJxAItWy1hA7N4b/r6X4g
J5deaDu4prTPMNZhZRCliMICwZYC0UH1yq0EuYxrnDfznvmrQs5Vhgr05ia7Xz0XAudj9GD3yOeft8mx
tPkI3oQoHuo4pYsQYxBiqr0yy6zf+Ek2+lJBiOm1XqV0JFg4ww==
SW1#sh run
Current configuration : 7040 bytes
! Last configuration change at 00:14:43 UTC Mon Mar 1 1993 by cisco
version 15.0
no service pad
hostname SW1
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c3750g-48ps
system mtu routing 1500
no ip domain-lookup
ip domain-name homemadelab
crypto pki trustpoint TP-self-signed-1649750784
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1649750784
revocation-check none
rsakeypair TP-self-signed-1649750784
crypto pki certificate chain TP-self-signed-1649750784
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31363439 37353037 3834301E 170D3933 30333031 30303034
33385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 36343937
35303738 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100C59D E8EABA4B 55B38199 CF68C6BA 7ACF2710 08B56CB5 840ECDE1 BFEBE97E
2027975E 683BB8A6 B4CF30D6 616510A5 88C202C1 9602D141 F5CAAD04 B98C6B9C
37F39EF9 AB42CE55 860AF4E6 26BB5F3D 1702E763 F460F7C8 E79FB7C9 B1B4F908
DE84281E EA38A58B 10631062 AABD32CB ACDFF849 36FA5241 88E9B55E A5742458
38C30203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 1484E351 45932C10 B36E4489 71F2EA89 8DBB5777 67301D06
03551D0E 04160414 84E35145 932C10B3 6E448971 F2EA898D BB577767 300D0609
2A864886 F70D0101 05050003 8181005C 0CB72BBB 9907AE7A FBB1A536 B7AED032
E837AAAB C7AEBD56 39F2B49F 5CB610D3 72700ED3 93514DA4 094C10FD 61AD644C
C7C5A1A1 C99C0D5D 9CDD3F43 57966813 8D0B8B3E B3A3AD6F C410F071 9608630E
0EA1CD1A 791F2EF8 77841886 1E5B50FA 8AE56F63 A987F55D 092D99C3 C99CE596
3B2F83BD E10B8759 5AFB5098 03BB8D
quit
spanning-tree mode pvst
vlan internal allocation policy ascending
ip ssh version 2
interface GigabitEthernet1/0/1
description Workstation
switchport access vlan 99
switchport mode access
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
switchport access vlan 4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
description Trunk-Link-to-SW3
switchport trunk native vlan 99
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
description Trunk-Link-to-SW2
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface Vlan1
no ip address
interface Vlan99
description Management
ip address 192.168.0.1 255.255.255.128
ip http server
vstack
line con 0
line vty 0 4
login local
transport input ssh
line vty 5
login local
transport input ssh
line vty 6 15
login
end
what sometimes help is to zeroize and then regenerate the RSA key (try different 'modulus' values:
R1#conf t
R1(config)#crypto key zeroize rsa
R1(config)#crypto key generate rsa modulus
