Cisco 2911 series router-computers will not connect to the Internet
willie01968
I am finally getting around to upgrading my router from 1911 to the 2911.  But I am having issues.
Building configuration...
Current configuration : 1403 bytes
! Last configuration change at 11:53:45 UTC Sat Dec 9 2023
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp excluded-address 192.168.125.1 192.168.125.10
ip dhcp pool main
 network 192.168.125.0 255.255.255.0
 default-router 192.168.125.1
 dns-server 8.8.8.8
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX1731AMXR
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address dhcp
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 192.168.125.1 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.0.1
access-list 1 permit 192.168.125.0 0.0.0.255
control-plane
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
I get successful pings
 Router#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/15/16 ms
Router#ping 192.168.0.1
Sending 5, 100-byte ICMP Echos to 192.168.0.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
Router#ping 192.168.125.14
Sending 5, 100-byte ICMP Echos to 192.168.125.14, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
Router#l pings with the default IP route, , DNS and the computer.
The computer can ping the router but cant get to the default route.
C:\Users\willie42>ping 192.168.125.1
Pinging 192.168.125.1 with 32 bytes of data:
Reply from 192.168.125.1: bytes=32 time<1ms TTL=255
Reply from 192.168.125.1: bytes=32 time=1ms TTL=255
Ping statistics for 192.168.125.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 1ms, Average = 0ms
C:\Users\willie42>ping 192.168.0.1
Pinging 192.168.0.1 with 32 bytes of data:
Reply from 192.168.2.1: Destination host unreachable.
Request timed out.
Request timed out.
Ping statistics for 192.168.0.1:
    Packets: Sent = 4, Received = 2, Lost = 2 (50% loss),
This configuration works perfectly on my 1921 cisco router.
I have the computer set to get its ip address from DHCP.  Checking the ipconfig /all
It appears to have picked up and ip address just fine.
Connection-specific DNS Suffix  . :
   Link-local IPv6 Address . . . . . : fe80::e420:77db:7778:90fc%3
   IPv4 Address. . . . . . . . . . . : 192.168.125.14
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Default Gateway . . . . . . . . . : 192.168.125.1
Now with my 1921 working as designed and testing by connecting my computer to the router that connects to my ISP and it working I am wondering if someone can point me in the right direction on what its wrong.  Any one with any ideas on troubleshooting I would appreciate it much.
There is only ip nat inside under interface which is use as
next-hop of default route
Is that all config?
If yes then you need to add interface for pc and config it with ip nat inside
And config interface use for
defualt route as ip nat outside
MHM
Is that all config?
MHM
