cisco 2911 Why open a Web page is very slow
xiao qiming
I am a novice, I have a 2911 router  with  some cisco 2950 switch    WAN is 4Mb fiber  Why open a Web page is very slow   when  I  have a workstation             below is config and NetworkTopology
Building configuration...
Current configuration : 5255 bytes
! Last configuration change at 02:03:02 UTC Thu May 24 2012
! NVRAM config last updated at 06:26:34 UTC Wed May 23 2012
version 15.0
service password-encryption
hostname penghai
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$ZG/.$UANvz6dWrsOZntVY5GeZi.
enable password 7 12415446425959
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.2.1
ip dhcp excluded-address 192.168.2.254
ip dhcp excluded-address 192.168.2.1 192.168.2.20
ip dhcp excluded-address 192.168.2.12
ip dhcp pool office
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   dns-server 202.96.134.133 202.96.128.68
   lease 2 2 2
ip dhcp pool kefang
   network 192.168.20.0 255.255.255.0
   default-router 192.168.20.1
   lease 2 2 2
no ip domain lookup
ip domain name yourdomain.com
crypto pki trustpoint TP-self-signed-3448292759
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3448292759
revocation-check none
rsakeypair TP-self-signed-3448292759
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
no ip address
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/1
ip address 180.105.69.25 255.255.255.0
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/2
ip address 192.168.0.254 255.255.255.0
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/2.1
encapsulation dot1Q 1 native
ip address 192.168.20.1 255.255.255.0
ip access-group 10 out
ip nat inside
interface GigabitEthernet0/2.10
encapsulation dot1Q 10
ip address 192.168.10.254 255.255.255.0
ip access-group 100 out
ip nat inside
interface GigabitEthernet0/2.40
encapsulation dot1Q 40
ip address 192.168.2.1 255.255.255.0
ip nat inside
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp pap sent-username 07450555112227@163.gx password 7 13212E312C2F2C1802
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool wan 180.105.69.25 180.105.69.25 netmask 255.255.255.240
ip nat inside source route-map kefang interface Dialer1 overload
ip nat inside source route-map office pool wan overload
ip route 0.0.0.0 0.0.0.0 180.105.69.26
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list standard lan-address
permit 192.168.0.0 0.0.255.255
access-list 2 permit 192.168.2.0 0.0.0.255
access-list 10 deny   192.168.2.0 0.0.0.255
access-list 10 permit any
access-list 20 permit 192.168.20.0 0.0.0.255
access-list 23 permit 192.168.2.0 0.0.0.255
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 192.168.20.0 0.0.0.255
access-list 100 permit tcp 192.168.2.0 0.0.0.255 host 192.168.10.1 eq 1433
route-map office permit 10
match ip address 2
route-map kefang permit 10
match ip address 20
control-plane
line con 0
password 7 005C425754095E
login
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 30 30
privilege level 15
password 7 154A5A5D54787E
login
transport input telnet ssh
line vty 5 15
access-class 23 in
login local
scheduler allocate 20000 1000
end
penghai#
cadet alain
can you try this:
int dialer1
ip tcp adjust-mss 1452
Regards.
Alain
5 Replies 5
cadet alain
can you try this:
int dialer1
Regards.
Alain
thank you   but the diraler1  is not  Connection      i only use   180.105.69.25   and the all users number is  one
GigabitEthernet0/0         unassigned      YES NVRAM  down                  down
GigabitEthernet0/1         180.105.69.25 YES NVRAM  up                    up
GigabitEthernet0/2         192.168.0.254   YES NVRAM  up                    up
GigabitEthernet0/2.1       192.168.20.1    YES manual up                    up
GigabitEthernet0/2.10      192.168.10.254  YES NVRAM  up                    up
GigabitEthernet0/2.40      192.168.2.1     YES NVRAM  up                    up
Dialer1                    unassigned      YES NVRAM  up                    up
NVI0                       unassigned      YES unset  administratively down down
Virtual-Access1            unassigned      YES unset  up                    up
here is ping to www.163.com
when i user  this command
Pinging 163.xdwscache.glb0.lxdns.com [121.14.228.43] with 32 bytes of data:
Request timed out.
Reply from 121.14.228.43: bytes=32 time=10ms TTL=55
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 121.14.228.43:
    Packets: Sent = 8, Received = 4, Lost = 4 (50% loss),
Approximate round trip times in milli-seconds:
    Minimum = 10ms, Maximum = 10ms, Average = 10ms
tracert  www.163.com
tracing route to 163.xdwscache.glb0.lxdns.com [121.14.228.43]
ver a maximum of 30 hops:
1    <1 ms    <1 ms    <1 ms  192.168.2.1
2     *        1 ms     *     113.105.69.14
3     1 ms     *        1 ms  121.15.179.161
4     *        2 ms     *     119.136.12.122
5     *        *        2 ms  183.56.64.6
6     *       10 ms     *     183.59.6.150
7     *       10 ms     *     121.11.75.198
8     *        *        *
Can you set  the following an give it a try:
no ip http access-class 23
no ip http authentication local
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
i don't have L3switch   only use cisco 2911 to connection  cisco 2950              is this right ?
hi,
i'm just curious, does your users experience the same slowness with other websites like yahoo or google?
i had a client who complained the same website (www.163.com) to be very slow but other websites works fine.
