CISCO 2921 ROUTER WITH LOUD NOISE
benojefua
I have a 2921 router which has suddenly started making a loud noise. I assume this is from the fans. The system LED light is also amber. Any ideas what might be causing this and ways to resolve?
Thanks.
@benojefua wrote:
Sep 25 2020 03:17:24.568 CAT: %MAINBOARD-3-I2CRW_ERROR: Read failure - Device @ 0x30, offset 0x00000001 on I2C bus 0
Contact Cisco TAC and organize for an RMA.
The sound you hear is the sound of the motherboard "frying" and the above logs prove it.
5 Replies 5
Leo Laohoo
What does the logs say?
Please see below what i have from the logs.
018988: Sep 25 2020 03:17:19.552 CAT: %IP_SNMP-4-NOTRAPIP: SNMP trap source GigabitEthernet0/0 has no ip address
018989: Sep 25 2020 03:17:24.568 CAT: %MAINBOARD-3-I2CRW_ERROR: Read failure - Device @ 0x30, offset 0x00000001 on I2C bus 0
018990: Sep 25 2020 03:17:24.568 CAT: %MAINBOARD-3-I2CRW_ERROR: Read failure - Device @ 0x30, offset 0x00000002 on I2C bus 0
018991: Sep 25 2020 03:17:29.584 CAT: %MAINBOARD-3-I2CRW_ERROR: Read failure - Device @ 0x30, offset 0x00000002 on I2C bus 0
  https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvd35848/?rfs=iqvred
  (possibly)
  M.
