Cisco 3725 Compatibility
dsteen
Does a Cisco 3725 support dual t1 CSU/DSU modules? (moduale model number vwic2-2mft-t1/e1. If so, how many at a time?
Giuseppe Larosa
Hello David,
according to following link
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8028d2db.html
yes.
you can install it in WIC slot or over Voice capable or data only network module.
so I imagine up to 4 modules.
Hope to help
Giuseppe
mlitka
Level 2
Level 2
Check out these documents:
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a00800e73f6.shtml
It appears like it might but not in a network module, you would need to add an AIM to get voice support. I would check with a sales engineer to make sure.
