Cisco 3850 MQC Qos conversion to Cisco 3750 MLS QoS assistance
Not applicable
I have the following Cisco 3850 MQC QoS configuration and need  assistance converting/reverting back  to a Cisco 3750 (12.2(50)SE4 MLS switch:
class-map match-any HighData
match access-group 101
class-map match-any AutoQos-4.0-Output-Multimedia-Conf-Queue
match ip dscp af41 af42 af43
match cos 4
class-map match-any AutoQos-4.0-Output-Bulk-Data-Queue
match ip dscp af11 af12 af13
match cos 1
class-map match-any AutoQos-4.0-Output-Priority-Queue
match ip dscp cs4 cs5 ef
match cos 5
class-map match-any CriticalData
match access-group 100
class-map match-any AutoQos-4.0-Output-Multimedia-Strm-Queue
match dscp af31 af32 af33
class-map match-any RateLimitedTraffic
match access-group 102
class-map match-any Video
match ip dscp af41
match dscp af41
class-map match-any Voice
match ip dscp ef
match dscp ef
class-map match-any non-client-nrt-class
class-map match-any AutoQos-4.0-Output-Trans-Data-Queue
match ip dscp af21 af22 af23
match cos 2
class-map match-any AutoQos-4.0-Output-Scavenger-Queue
match ip dscp cs1
class-map match-any AutoQos-4.0-Output-Control-Mgmt-Queue
match ip dscp cs2 cs3 cs6 cs7
match cos 3
policy-map port_child_policy
class non-client-nrt-class
bandwidth remaining ratio 10
policy-map AutoQos-4.0-Output-Policy
class AutoQos-4.0-Output-Priority-Queue
priority level 1 percent 30
class AutoQos-4.0-Output-Control-Mgmt-Queue
bandwidth remaining percent 10
queue-limit dscp cs2 percent 80
queue-limit dscp cs3 percent 90
queue-limit dscp cs6 percent 100
queue-limit dscp cs7 percent 100
queue-buffers ratio 10
class AutoQos-4.0-Output-Multimedia-Conf-Queue
class AutoQos-4.0-Output-Trans-Data-Queue
class AutoQos-4.0-Output-Bulk-Data-Queue
bandwidth remaining percent 4
class AutoQos-4.0-Output-Scavenger-Queue
class AutoQos-4.0-Output-Multimedia-Strm-Queue
class class-default
bandwidth remaining percent 25
queue-buffers ratio 25
policy-map WAN
class Voice
set dscp ef
class Video
set dscp af41
class CriticalData
set dscp af31
class HighData
set ip dscp af21
class class-default
policy-map AutoQos-4.0-Trust-Cos-Input-Policy
class class-default
set cos cos table AutoQos-4.0-Trust-Cos-Table
policy-map LAN
class Video
class HighData
set dscp af21
class RateLimitedTraffic
set dscp 1
class CriticalData
set dscp af31
class class-default
policy-map AutoQos-4.0-Trust-Dscp-Input-Policy
class class-default
set dscp dscp table AutoQos-4.0-Trust-Dscp-Table
access-list 10 remark Critical Data (AF 31)
access-list 10 deny ip any any fragments
0 Replies 0
