Cisco 3850 To Fortigate 60E OSPF Connection Via EtherChannel
xxsamixx18
I am trying to set up a connection via OSPF between my Cisco 3850 layer 3 switch and my FortiGate 60E firewall throw OSPF, but it's not working, has anyone done it before. I pasted my configuration below, note if you see misconfiguration it is just me trying different thing to make it work so far no luck.
interface Port-channel1
no switchport
ip address 10.240.240.2 255.255.255.252
ip pim sparse-mode
ip ospf authentication-key 7 121A0A05430E470524
ip ospf dead-interval 40
ip ospf mtu-ignore
ip ospf 901 area 0
ip ospf cost 10
ipv6 address 2001:4000:FD60:C10:240:240::/64
ipv6 enable
ipv6 ospf 900 area 0
ipv6 ospf cost 10
end
ITS-Core-BS1#sh run int gi1/1/1
Building configuration...
Current configuration : 141 bytes
interface GigabitEthernet1/1/1
description Link To FW-60E
no switchport
no ip address
ip ospf 901 area 0
channel-group 1 mode on
end
ITS-Core-BS1#sh run int gi1/1/2
Current configuration : 113 bytes
interface GigabitEthernet1/1/2
no switchport
no ip address
ip ospf 901 area 0
end
config router ospf
set router-id 10.10.0.10
config area
edit 0.0.0.0
next
end
router ospf 901
router-id 10.10.0.100
network 10.10.0.100 0.0.0.0 area 0
network 10.240.240.0 0.0.0.3 area 0
config ospf-interface
edit "CISCO-OSPF"
set interface "Port-Channel 1"
set authentication text
set authentication-key ENC 6EAg4vNk5Wh/bE4QWTApWGmCT3ON8WS+ViZMeWRJRJKvpctlqD2hB+08d5uXP1SsqbPQuaWiipuqrSjUGR/j8BuEH4eOPKm8VdyV7rg8Dsq60cLGXpKKURqqUMkASLOy4Q12gtFE4V+KHtGxvXvostmzBumFcunBP1DuRIgPL2e9i4AKQvbXT4ghEy+AsRnk0whWGg==
set cost 10
set dead-interval 40
set hello-interval 10
set mtu-ignore enable
next
edit "Loop"
set interface "FW OSPF Loop"  <<< Passive enabled
set cost 10
next
end
config network
edit 1
set prefix 10.240.240.0 255.255.255.252
next
edit 2
set prefix 10.10.0.10 255.255.255.255
next
end
5 Replies 5
Leo Laohoo
For the sake of troubleshooting, I'd remove the OSPF authentication because it is at a broken state (and serves no purpose).
conf t
router ospf 901
 NO passive-interface Po1
end
Next, I'd run a debug from the switch.
1.  Disable the port.
2.  Command: debug ip ospf events
3.  Enable the port
4.  Wait for 45 seconds worth of output and disable the debug (undebug all).
5.  Put the output from Step 4 into a text file and attach it.
Hello
no switchport
ip ospf 901 area 0
ip ospf cost 10
ipv6 enable
ipv6 ospf cost 10
router ospf 901
You have OSPV2-3 running so would expect your cfg to accommodate both versions?
ip routing
ipv6 unicast-routing
router ospfv3 901
address-family ipv4 unicast
exit-address-family
address-family ipv6 unicast
exit-address-family
Kind Regards
Paul
ip routing and ipv6 uncast-routing is enabled
No switchport under port member of port channel and you add ospf under it?
I think you misconfig ospf
You need to
-Under port member
1- use no switchport
2- no IP and no ospf config
- under port channel
1- add no switchport
2- add IP
3- add ospf
- under ospf
Disable lls if it enable if it disable enable it' I dont know if forti use lls or not
MHM
Hello
i dont see any ospfv3 routing process to either the cisco/fortigate -unless that is your just not showing it?
Kind Regards
Paul
