Cisco 4331 router reset
sudeshgh
why my router 4331 reset after restarting
2 Accepted Solutions
Leo Laohoo
Post the complete output to the command "sh version".
Config-registry value of 0x142 means "ignore/by-pass router configuration file".
So this means that every time the router boots/reboots the router will come up without any configuration.
7 Replies 7
Seb Rupik
Have you set the config-reg to ignore the startup configuration?
What is the output of: sh ver | inc Config.*reg
cheers,
Seb.
Leo Laohoo
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 17-Oct-16 20:23 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
CCF_CHANDRAPUR uptime is 17 hours, 57 minutes
Uptime for this control processor is 17 hours, 58 minutes
System returned to ROM by reload
System image file is "bootflash:isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 FoundationSuiteK9 Permanent FoundationSuiteK9
securityk9
appxk9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None appxk9
uck9 None None None
securityk9 None None securityk9
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4331/K9 (1RU) processor with 3696789K/6147K bytes of memory.
Processor board ID FDO2117A0K4
3 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
7081983K bytes of flash memory at bootflash:.
Configuration register is 0x142
Someone rebooted the router.
WTF is this?   Is someone playing tricks?
who playing tricks?
ok
