cisco 4331 with SM-X 16/24 ports card
antonkolev
Is someone has experience with cisco 4331 with SM-X card
If I have LAN base image for SM-X card and base image for 4331 router - Can I configure SVI interfaces on the router and then place particular L2 vlan  to access one of the port on the SM-X card
Also I was curious - for the router and for the card - its a single management - correct
If I log in to the router I can see output from  # sh int status and see all interface status on the card
I just wonder if its similar like ISR 1811 router with build in switch - I can run dynamic protocol , enable QoS and have bunch of vlans and SVi
Let me know
antonkolev
Someone knows How to map ports from SM-X cards with LAn base image to the router
Seems like port gig 0/26 is trunked to the router
