Cisco 5915 Prompt Question Problem
embeddedman
I'm using Cisco 5915 (C5915-ENTBASE-M, v.15.6) over serial port with a linux machine. I am in trouble in terminal while answering router questions with an application which uses serial port.
When I want to pass into EXEC mode over serial terminal via SSH:
router>enable (press enter)
Password: 1234 (press enter)
router#
This is OK.
But when I wanted to do this with an application using serial port in canonical mode:
read()=> "router>"
write("enable\r");
***Here it is waiting about 30 sec***
read()=> "Password:"
read()=> "% Password: timeout expired"
So, I can not catch "Password:" prompt in time. I think, when router wants to ask a question, it does not send a carriage return. That means read block does not include a carriage return and I can not read serial port because of usage of serial port in canonical mode. Also, I configured serial port for '\r' character beside of '\n'.
Do you have any idea about this issue ?
CEE95
Hello embeddedman.  Can you provide more information on the configuration on the serial connection?
Hi CEE95,
Basic configuration is
c_lflag = ICANON;
c_oflag = OPOST;
c_iflag = ICRNL;
memset(c_cc, 0, NCSS);
c_cc[VEOL] = '\r';
But I think, problem is CISCO does not send any EOL character. So, I can not catch anything while it prompting a question. I guess, I need to use serial port in incanonical mode ?
