02-13-2015 10:44 AM - edited 03-05-2019 12:47 AM
We are planning to replace the existing two boarder gateway router with two cisco 6504 or 6503 series Switch.
1.We will have two different Uplink Provider, One from one L3 Switch and another one is from other L3 Switch.
2.We are accepting full BGP routing table ( How much memory require?)
3.require at least 4 10gig port at each Router.
For this pls recommend is cisco 6504/6503 is appropriate for these purpose.How much ram we need for BGP routing table and module we require.
I have attached the network diagram for reference.( Router A and Router B need to be replaced)
Thank you very much.
-Ishwar
Solved! Go to Solution.
02-13-2015 01:10 PM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
When you say a full BGP routing table, do you mean the full Internet BGP routing table?
If so, you'll want supervisors with XL suffixes (ditto for any DFCs).
Also if so, yes, you should be able to use a 6503 or 6504.
For 4x10g, you can use either the 6704, 6708 or 6716, the latter two are oversubscribed.
With a sup2T (which also has dual 10g on the sup), you can also use the 6908, which isn't oversubscribed.
02-13-2015 01:10 PM
Disclaimer
Posting
