Cisco 6509 E Switch Port Configuration
chris.arbob1
I am in the process of moving a data line  with a Riverbed to my WAN provider's data centre. The plan is to connect the Riverbed to a Cisco 6509E switch.
The LAN Port on the Riverbed SH550  runs at 100MB ( 1000GB not supported). My WAN provider has now told me that it is not possible to configure a port on the Cisco 6509E to run at 100MB - only 1GB is supported. Is this correct ? Information on the internet suggests the hardware supports fast Ethernet. Could my WAN provider have acquired a hardware version of the 6509E switch that does  not support 100MB ? This is a core switch in the WAN provider's network. Could there be a Network design issue that disallows 100MB ports ?
Mark Malone
Its most likely the blades he has in the 6509E  , I have 6509Es VSS and others , some blades are 10100/100 some only 1000 or 10gb, As below 6748s support 100mbs
xxxx(config-if)#speed ?
  10    Force 10 Mbps operation
  100   Force 100 Mbps operation
  1000  Force 1000 Mbps operation
  auto  Enable AUTO speed configuration
xxxx(config-if)#do sh ver | i 6509
cisco WS-C6509-E (M8572) processor (revision ) with 1769472K/262144K bytes of memory.
xxxx(config-if)#
Mod Ports Card Type                              Model              Serial No.
  1    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE
  2    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE
  5    5  Supervisor Engine 2T 10GE w/ CTS (Acti VS-SUP2T-10G
  7   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX
  8   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX
Mark Malone
xxxx(config-if)#
chris.arbob1
Thankyou Mark for your response.  You have answered my question Much appreciated
