Cisco 7206 Commands
cindylee27
Hi All,
I am trying to find the Reference Commands for 7206 but I could not get it from the cisco website. Have tried to search but in vain.
Anyone has the idea where i can get a full set of the commands reference for 7206?
Thanks in advanced.
5 Replies 5
spremkumar
Level 9
Level 9
Did you try to check out for command reference guides of IOS versions ???
http://www.cisco.com/en/US/products/ps6350/prod_command_reference_list.html
regds
Hi Sprem,
Thanks..but what i am looking for is the specified IOS Commands that I can use for 7206...
Diff routers will have diff type of IOS commands..basically i am looking for 7206 IOS commands.
thanks again,
HI,[ Pls Rate if HELPS]
Refer link below for Cisco 7206 Product reference and Documentation site:
http://www.cisco.com/univercd/cc/td/doc/product/core/7206/index.htm
We would like to know, what is the Current IOS Version do you use in Cisco 7206 Router:
Pls refer link below for documentation site (7206 Router + 12.4 IOS Release):
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/index.htm
(7206 Router + 12.3 IOS Release):
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/index.htm
PLS RATE if HELPS
Best Regards,
Guru Prasad R
Hi Cindy,
Kindly check this out:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/index.htm
And the link provided by Edwin is more granular.
And please note that the difference between the IOS commands between Cisco routers is not that huge (if we are talking up to the 7200 series, above this series the life is somehow different).
HTH,
Mohammed Mahmoud.
okie..I will check through the links..thanks..
