11-24-2009 02:46 AM - edited 03-04-2019 06:47 AM
Could you please tell me, will this modules work with 7206 NPE-G2 or not? Because in this document
I don't see this modules in capability list for NPE-G2, although I know what, for examle, GLC-LH-SM perfectly works with NPE-G2 but don't present in this list. Could you clear up situation?
11-24-2009 04:53 AM
Hello Roman,
according to NPE-G2 datasheet only conventional SFP are mentioned
http://www.cisco.com/en/US/prod/collateral/routers/ps341/product_data_sheet0900aecd8047177b.html
this does not mean that these special GLCs are not supported
http://www.cisco.com/en/US/docs/routers/7200/install_and_upgrade/gbic_sfp_modules_install/5067g.html
even here they are not mentioned.
So I'm afraid they are not supported on C7200 NPE-G2.
Hope to help
Giuseppe
11-24-2009 04:47 PM
Only SX, LX/LH & ZX are supported but sold separately.
11-24-2009 10:43 PM
I don't know why you are so sure what it will not work? I have also seen what where is no mention to this modules in capability matrix, but just now I've inserted two AlliedTelesyn SM SFP into NPE-G2 connect it to each other and they work!
As far as I understand SFP has absolutely standart electrical interface. Why are there such misinformation in oficial cisco documentation?
11-25-2009 01:42 PM
Hi Roman,
When inserting non-Cisco SFPs into Cisco appliance, there are instances where the ports will go into error-disable. This is because Cisco-branded SFP (although never made by Cisco) has an algorithm inserted into the EIPROM. The appliance will always interrogate the EIPROM and see if the algorithm matches. If not, then it's disabled. Cisco TAC tends NOT to support any issues if they found out you have non-Cisco branded parts.
