08-14-2013 04:32 AM - edited 03-04-2019 08:45 PM
Hello All,
We currently have a Cisco 7206VXR router. It had three RJ45/SFP ports and all are currently being used. Would anybody know if there is a possibility to add a submodule that can add another gig port to it ?
Nilesh
08-14-2013 05:43 AM
Use an ethernet switch for best results.
08-14-2013 08:55 AM
Hi Nilesh,
If you have a free slot on the Cisco 7206 VXR device then you can try adding a PA-GE module which will give you the GiG port that you are looking out for.
***********Plz do rate this post if you found it helpful*************************
Thanks & Regards,
Vignesh R P
08-14-2013 08:56 AM
Vignesh Rajendran Praveen wrote:
Hi Nilesh,
But will not give decent performance, like the on-board interfaces do.
08-14-2013 08:59 AM
Hi Nilesh,
But I have not heard that complaint from any of my customers though 🙂 They seem to be happy with its performance. But still the choice is yours.
Thanks & Regards,
Vignesh R P
08-14-2013 09:16 AM
I worked at Cisco San Jose, at the time PA-GE was introduced, and did a performance report. About 250 Mbps/sec bidirectional with NPE-400. How you advice your customes, the choice is yours.
