Cisco 7600 Series SPA Interface Processor-600 compatibility
Alan Boyd
Quick question: does the Cisco 7600 Series SPA Interface Processor-600 (7600-SIP-600-DC) only support a single SPA, e.g.
1 x SPA-OC192POS-XFP?
The 10Gbps through put on the 7600-SIP-600-DC and http://www.cisco.com/en/US/prod/collateral/routers/ps368/product_data_sheet0900aecd8033998f_ps708_Products_Data_Sheet.html appears to show that this is the case.
Giuseppe Larosa
Hello Alan,
with 10Gbps BW capabilities it would not be wise to install two
1 x SPA-OC192POS-XFP SPA on the SIP 600
to be noted table-1 of the document you have linked says:
Modularity
One SPA per Cisco 7600 SIP 600 module
It may be possible to install two SPAs to have a cold standby, but only one SPA should be used.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Alan,
Modularity
Hope to help
Giuseppe
Thanks! Appreciated.
Alan
