09-19-2016 06:54 AM - edited 03-05-2019 07:05 AM
Hi ,
i am planning to buy cisco 7606 router with 720 3CXL GE switch processor and SIP 400 module need to know will it support PPPOE or any additional module will be required . we need to have 3000 concurrent PPPOE session . please some one advise should i buy this router .
09-19-2016 08:22 AM
I can't find any official docs about this, but I read somewhere about version 2 (V2) SPAs being required for PPPoE with SIP-400, which supports up to 8K PPPoE sessions:
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/shared_port_adapters/configuration/7600series/sipspasw/76cfgsip.html#74694
If you only need the device for PPPoE (or at least if you don't require switching / layer2 features in the same box) I'd get an ASR1K...
09-20-2016 07:57 AM
Thanks , also can you help what IOS will be required and some working config for AAA / PPPOE config on this router.
