Cisco 819 - Cellular 0 goes down when Interface Goes Up
ncastro05
I've been able to activate and configure the Cisco 819 router to connect to Verizon via interface Cellular 0 but when I connect a laptop to the router, int Cell 0 goes down.
Here's a snippet of what happens after I connect a laptop:
rt1#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Jan 24 23:27:38.843: %LINK-3-UPDOWN: Interface Cellular0, changed state to up.!!!
Success rate is 60 percent (3/5), round-trip min/avg/max = 160/164/168 ms
rt1#
Jan 24 23:27:38.883: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0, changed state to up
rt1#ping 8.8.8.8
Success rate is 100 percent (5/5), round-trip min/avg/max = 164/180/212 ms
rt1#ping 8.8.8.8
Success rate is 100 percent (5/5), round-trip min/avg/max = 172/203/256 ms
rt1#
Jan 24 23:28:03.083: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
Jan 24 23:28:04.083: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
rt1#
Jan 24 23:28:16.755: %LINEPROTO-5-UPDOWN: Line protocol on Interface Cellular0, changed state to down
rt1#
Jan 24 23:28:18.755: %LINK-5-CHANGED: Interface Cellular0, changed state to reset
rt1#
Jan 24 23:28:23.799: %LINK-3-UPDOWN: Interface Cellular0, changed state to down
rt1#
Jan 24 23:28:32.119: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
rt1#
Thank you for your help!
Edit: Here's the current config:
Building configuration...
Current configuration : 5818 bytes
! No configuration change since last restart
version 15.1
service password-encryption
hostname ########
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 #####################
no aaa new-model
clock timezone CST -6 0
clock summer-time CDT recurring
crypto pki trustpoint TP-self-signed-###############
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-#########
revocation-check none
rsakeypair TP-self-signed-#########
crypto pki certificate chain TP-self-signed-##############
certificate self-signed 01
        quit
ip source-route
ip cef
ip dhcp excluded-address ###########
ip dhcp pool ccp-pool
import all
network ######### #########
default-router ##########
lease 0 2
ip dhcp pool ccp
no ip domain lookup
ip domain name ems.evgonetwork.com
no ipv6 cef
vpdn enable
vpdn-group 1
chat-script cdma "" "ATDT#777" TIMEOUT 60 "CONNECT"
license udi pid C819G-V-K9 sn ##########
username ####### secret 5 ###################
controller Cellular 0
interface Loopback0
ip address ######### #########
interface Cellular0
ip address negotiated
encapsulation ppp
dialer in-band
dialer idle-timeout 30
dialer string cdma
dialer-group 1
no peer default ip address
async mode interactive
ppp chap password 7 #############
interface FastEthernet0
description DreamPlug
no ip address
interface FastEthernet1
description HMI Display
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
description POE Switch / Cameras
no ip address
interface GigabitEthernet0
no ip address
shutdown
duplex auto
speed auto
interface Serial0
no ip address
shutdown
clock rate 2000000
interface Vlan1
description default
no ip address
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 Cellular0
access-list 1 permit any
dialer-list 1 protocol ip list 1
no cdp run
snmp-server location ########
snmp-server contact #############
control-plane
banner login ^C
This computer system, including all related equipment, are provided for
authorized use only. Use of this computer system, authorized or unauthorized,
constitutes your consent to monitoring. Unauthorized use may subject you
to criminal prosecution. If you are not authorized to access this system,
disconnect now.
^C
line con 0
logging synchronous
login local
line aux 0
line 3
exec-timeout 0 0
script dialer cdma
login
modem InOut
no exec
rxspeed 3100000
txspeed 1800000
line vty 0 4
access-class 23 in
privilege level 15
logging synchronous
login local
transport input telnet ssh
scheduler allocate 20000 1000
end
0 Replies 0
