Cisco 819 DDR 3G with floating static route - 3G Flapping!
I have a new Cisco 819 router wtih Verizon 3G built in.  I want to use this router to provide 3G backup Internet access for a customer kiosk.
The 3G is perfectly stable when I use it as a primary, static routed connection.  When I use a floating static route, the link goes up and down constantly.
The 3G link works for a about 20-  30 seconds, then goes to reset, down, then dials up and reconnects.
What am I missing?
Attached is the config and debug log file.
Aaron Gabrielson
Here is my config:
version 15.1
hostname Scale2_Cisco819
boot-start-marker
boot-end-marker
enable secret 5 XXXXXXXXXXXXXXXXXXXXXX
no aaa new-model
clock timezone PCTime -7 0
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
ip source-route
ip cef
ip domain name xxx.xxx
ip name-server 8.8.8.8
no ipv6 cef
chat-script verizon3G "" "ATDT#777" TIMEOUT 60 "CONNECT"
license udi pid C819G-V-K9 sn XXXXXXXXXXX
username admin privilege 15 secret 5 XXXXXXXXXXXXXXXXXXXXXXXX
controller Cellular 0
track 234 ip sla 1 reachability
interface Cellular0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation ppp
dialer in-band
dialer idle-timeout 2147483
dialer string verizon3G
dialer-group 1
async mode interactive
no ppp lcp fast-start
ppp chap password 0 cisco
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface GigabitEthernet0
description $ES_WAN$
ip address 10.2.1.170 255.255.0.0
ip nat outside
duplex auto
speed auto
interface Serial0
shutdown
clock rate 2000000
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$
ip address 10.4.7.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
ip local policy route-map track-primary-if
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map nat2cell interface Cellular0 overload
ip nat inside source route-map nat2ge interface GigabitEthernet0 overload
ip route 0.0.0.0 0.0.0.0 10.2.1.1 track 234
ip route 0.0.0.0 0.0.0.0 Cellular0 10
ip sla 1
icmp-echo 10.2.1.171 source-interface GigabitEthernet0
ip sla schedule 1 life forever start-time now
access-list 1 permit any
access-list 101 permit ip 10.4.7.0 0.0.0.255 any
access-list 102 permit icmp any host 10.2.1.171
dialer-list 1 protocol ip list 1
no cdp run
route-map track-primary-if permit 10
match ip address 102
set interface GigabitEthernet0
route-map nat2ge permit 10
match ip address 101
match interface GigabitEthernet0
route-map nat2cell permit 10
match interface Cellular0
control-plane
line con 0
login local
line aux 0
line 3
exec-timeout 0 0
password cisco
script dialer verizon3G
login
modem InOut
no exec
rxspeed 3100000
txspeed 1800000
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler allocate 20000 1000
end
I took the floating routes out and I am still getting the problem the cellular0 interface going up and down.
I think it might have something to do with my NAT settings.  When I set the cellular0 connection for the only NAT entry, the connection is stable.  With the two NAT entries with the route-map policies I am having problems.
Is there something wrong with my NAT setup in the above config? Or maybe with the access-lists referenced by the route-maps maybe?
Aaron G.
