Netflow export to remote server on a different subnet
Cesar Alvarado
Hello All,
I´m wondering if anyone of you have configured Netflow export to a remote analyzer on a different subnet. Basically what I´m trying to do is export the statistics of one of my routers to the public IP of my local router and then NAT those statistics to my local Analyzer. I don´t know if NAT will do the job for me but looks like the server is not receving the statistics cache from the remote router
TOPOLOGY
ROUTER1(Netflow export) ------------->ROUTER2------------->Analizer
Remote1:
ip flow-cache entries 52000
ip flow-cache timeout active 1
ip flow-export source Cable-Modem0/0/0
ip flow-export version 5
ip flow-export destination (remote router WAN IP) 9997
ip flow-top-talkers
top 50
sort-by bytes
cache-timeout 5000
WAN port
interface Cable-Modem0/0/0
description ***Primary link ISP1**
ip address dhcp
ip flow ingress
ip nat outside
ip inspect ATM out
ip virtual-reassembly
load-interval 30
no fair-queue
crypto map clientmap
Router2
interface FastEthernet0/0/0
ip address (WAN IP)
description OUTSIDE
ip dhcp client route track 456
ip address dhcp
ip nat outside
load-interval 30
duplex auto
speed auto
end
ip nat inside source static tcp (Analizer IP) 9997 (WAN IP) 9997 extendable
ip flow-export source FastEthernet0/1
ip flow-export destination (Analyzer IP) 9997
ip flow-top-talkers
top 50
sort-by bytes
cache-timeout 5000
Any good documents or configs related to this
Thank you
Don Jacob
I see that you have "ip nat inside source static tcp (Analizer IP) 9997 (WAN IP) 9997 extendable". But NetFlow packets are UDP. Can you try changing it to UDP? It should work provided the NATing occurs as expected.
Don Thomas Jacob
www.netflowanalyzer.com
NOTE: Please rate posts and close questions if your query has been answered
Regards, Don Thomas Jacob http://www.solarwinds.com/netflow-traffic-analyzer.aspx Head Geek @ SolarWinds NOTE: Please rate and close questions if you found any of the answers helpful.
