09-06-2005 11:17 AM - edited 03-03-2019 10:26 AM
Hello
I ve a "small" problem, I have no more IOS on the flash memory on a cisco 827 router. So I think I should not reboot it .
The problem is that I have only a guest account on cisco.com, so I can't download the IOS.
What can I do in order to resolve this problem ?
Thanks in advance, your help is _very_ _very_ welcome.
09-06-2005 08:46 PM
Its very difficult to procure software, unless you have smartnet contract on the router, so that you can download it off CCO (login required). If you lose the original image, you cannot restore it back other than through downloading it off another router (with similar image) or from CCO.
09-06-2005 09:01 PM
cisco made it difficult for some reasons... Hopefully there are some people on P2P networks that share their files...
I found an IOS for my router, and now it works again.
