Cisco 836 with ADSL NAT and VPN
Carsten Radke
Hallo,
I try to configure the 836, to work with the Cico VPN-Client.
The client connects to the router from outside but my problem is that the nat from inside LAN to the internet is not working.
here's a bit of log from nat:
*Mar 6 23:48:02.585: NAT: map match nonat
*Mar 6 23:48:02.585: NAT*: Can't create new inside entry - forced_punt_flags: 0*Mar 6 23:48:02.585: NAT: map match nonat
I don't know what I do wrong, please help.
config in attachment,
Carsten
2 Accepted Solutions
I am really sorry, Nat 0 is about other reply, I posted wrong place. I have modified my reply.
look at your configuration:
ip nat inside source route-map nonat interface Dialer1 overload
Dialer1 ?? I think Dialler 0 is right.
bamboo
you put
ip nat outside
in Dialer0 interface
but you put Dialer1 in
therefore the NAT does not work
change
to
ip nat inside source route-map nonat interface Dialer0 overload
dongdongliu
Dialer1 ??
Hi dongdonqliu,
but nat 0 is for traffic that will not be natted.
Any traffic to the internet have to nat.
could you explain me your message, please ?
bamboo
you put
ip nat outside
change
to
