CISCO 837 - TCP Open Port Issue
imranmohammed
Cisco 837
I have enabled the basic firewall rules via SDM, is it possible to open port “54321” for torrents to a workstation IP 10.10.10.2. I have tried to add a rule, but it still shows stealth at the “shields up” test @grc.com.
Btw; when the firewall is setup using CWRS it opens 139 NetBIOS, and it further prevents changing of any rules, SDM shows them as read-only.
Any help would be much appreciated,
Imran
thisisshanky
Level 11
Level 11
I could probably help you out with the CLI configs, if you can paste the configs. (mask ip addresses/passwords)
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Hi,I had to reset the router to factory settings via the CWRS because I couldn't access the Internet, something which I may have done with the firewall I suppose.
The following attached file is the running config accessed from SDM
Thanks for your help,
