Cisco 851 DMZ
kevinlibre
Can anyone tell me if the 851 supports setting up a DMZ? If so, can you point me to the docs on how to do it?
thanks.
Collin Clark
I don't believe the 850 series supports a DMZ (870 does though).
Hope that helps.
You can configure one of your ports with an IP address, and then create another VLAN. Make that switchport a member of the VLAN. If you don't have the option of creating VLANs, you won't be able to do it.
Router#vlan-switch
Router(vlan-switch)#vlan100
Router(vlan-switch)#exit
Router#
It may tell you that you already have the max amount of vlans that the switch supports.
--John
HTH, John *** Please rate all useful posts ***
