Cisco 857 on SBC/AT&T DSL circuit
logan-7
Ok, for What ever reason I can not get the 857 to connect to this DSL service. The OK light is on, the CD light is on but the the OK-DATA WAN is blinking. I have the Encapsulation as PPPoE and the VCI/VPI numbers in and the login and password that was set up for the circuit. But it is not connecting. I put a Speedstream on it to verify that the DSL signal was present and it worked beautifully. I need the Cisco 857 on it for the security and because I have to set up a VPN after the connection is established, but haven't even gotten there. Any Idea's????????
Already went through that and none of it applies.
I think that my issues is I was using the SDM interface and I need to use CLI to configure it correctly.
IF you know any other reasons let me know? thanks
