Cisco 857W connection/config problems
emesj2007
Hi all
My problem is that I can connect to some sites but not others and parts of some sites but not all of it. For instance I can't connect to cisco.com at all but I can connect to whirlpool and view pages but when I go to post and click show preview it hangs indefinately. Its always the same sites that it can't connect to.
I will post my config below if anyone can see whats wrong
Thanks heaps in advance
version 12.4
no service pad
service password-encryption
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.1.1
ip dhcp pool sdm-pool
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 203.x.x.191
lease 0 2
ip cef
ip domain name yourdomain.com
crypto pki trustpoint TP-self-signed-48296268
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-48296268
revocation-check none
rsakeypair TP-self-signed-48296268
crypto pki certificate chain TP-self-signed-48296268
certificate self-signed 01 nvram:IOS-Self-Sig#2.cer
username xxxxxxxxxx privilege 15 password 7 xxxxxxxxxxxxxx
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.5 point-to-point
description $ES_WAN$
no snmp trap link-status
pvc 8/35
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
ip nat inside
ip virtual-reassembly
interface Dialer0
description $FW_OUTSIDE$
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username xxxxxxxxxxxxxxxx password 7 xxxxxxxxxxxxxxxx
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 100 interface Dialer0 overload
access-list 100 permit ip 192.168.1.0 0.0.0.255 any
dialer-list 1 protocol ip permit
no cdp run
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 100 in
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
paolo bevilacqua
check if you can 'ping x.x.x.xdf size 1500' hwere x.x.x.x is your default gateway, or find the smaller value that works. Subtract 40 and configure accordingly 'ip tcp adjust-mss' under dialer interface.
Also if you configure "ppp ipcp route default" and "ppp ipcp dns request", you can do without the static route at dialer, and manually configuring dns.
