Cisco 866VAE - Datasheet/Specifications
it
Community Member
Dear all, we urgendly need to know wich Firewall type uses Cisco 866VAE Router.
Unfortunately we cant find the datasheet/specifications for this model. When we go to the productsite on http://www.cisco.com/c/en/us/support/routers/866vae-integrated-services-router-isr/model.html#DataSheets, there are a lot of products but no entry with 866VAE.
Wich one is the right one for 866VAE?
Thanks for your help!
Glenn Martin
Moving Post to appropriate community for greater visibility.
e.ciollaro
Level 9
Level 9
HI
why do you think to use 880 or 836 data sheet if you has a 860VAE ?
Hi think the right datasheet is "Cisco 860VAE Series Integrated Services Routers Data Sheet"
http://www.cisco.com/c/en/us/products/collateral/routers/800-series-routers/data_sheet_c78-693249.html
Bye,
enrico
