Cisco 877w disable password.
wangkiantjun
as the title above, i want to disable cisco 877w router password. i knew the password. the problem is, once after boot & type password, keyboard any key cannot type. the keyboard no problem at all when i type "boot" for booting. i can only at rommon mode. once i boot & entering password, any key also cannot key in. so what i should do?
Nagaraja Thanthry
When you are at ROMMON, type "confreg 0x2142". This will disable the
password requirement. Then boot the router. You will come to "Router>" mode.
Go to enable mode (type "enable") and then copy the stored configuration to
a text file (issue "show start" command and copy all the output to a text
editor) and remove the password (if you have aaa configuration, then issue
"no aaa new-model" command). Then copy rest of the configurations back to
the router. Then, go to configuration mode and type "config-reg 0x2102",
exit out of the config mode and save the configuration (write mem). The
procedure is also listed in the link below.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_password_recov
ery09186a0080094675.shtml
Hope this helps.
NT
Leo Laohoo
If NT's post (+5) above doesn't work for you, then the next one carries a disclaimer.
Using this process, the CONFIG of your router will be erased and the router will be reset back to factory default.
At the back of your 877W router is a "Reset" button.  Turn the router off, hold down the Reset button and turn on the router.  Wait for about 10 seconds before releasing it.
Please don't forget to rate useful posts.  Thanks.
