Cisco 881 Port Forwarding Config
doug.shrout
Let me first apologize for my lack of knowledge in IOS and Cisco products, a client of mine recently purchased a Cisco 881 and is trying to achieve simple results.
First he would like two ports forwarded to his internal webserver (80, 5900).
Secondly he wants to setup a VPN solution so he can access his network from home using the Cisco VPN Client.
After much reading I have created a configuration for the device to take care of his first request. I have not attempted the VPN side of the project at all as I want to be sure I am headed in the right direction and I am understanding everything correctly. Below is the current configuration of the device. Is this configuration correct for trying to acheive step 1 of what he would like me to configure?
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.05.31 18:16:08 =~=~=~=~=~=~=~=~=~=~=~=
show run
Building configuration...
Current configuration : 8186 bytes
! Last configuration change at 17:27:25 PCTime Thu May 31 2012 by cisco
! NVRAM config last updated at 17:27:23 PCTime Thu May 31 2012 by cisco
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname compgallery
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret 5 $1$fpXD$p3Mkcm1fxW7zdPxYczd/h/
no aaa new-model
memory-size iomem 10
clock timezone PCTime -5
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-2031701705
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2031701705
revocation-check none
rsakeypair TP-self-signed-2031701705
crypto pki certificate chain TP-self-signed-2031701705
certificate self-signed 01
  3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32303331 37303137 3035301E 170D3132 30353331 32323133
  32395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 30333137
  30313730 3530819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100CDA4 7793B847 0DAFCE01 8B98A945 11B25D8A 868F98CE C47C92BF C0EE01FF
  CE7544EA 811E3012 4E9D1FD7 A693A292 3B8E40B9 264089A2 87BEC114 A3CBE27F
  853837BB 9DB63E79 029D647E D302A640 BEDB1A2C 61686A40 AA334625 AE44B92B
  7288BE92 532D2D07 BFD83243 184BDE8D 03C3AE50 B18D8902 2076DD13 AEF50493
  B0DF0203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
  551D1104 1B301982 17796F75 726E616D 652E796F 7572646F 6D61696E 2E636F6D
  301F0603 551D2304 18301680 145BC724 3F863D14 26FB30EE 058200DC 97A5DF00
  10301D06 03551D0E 04160414 5BC7243F 863D1426 FB30EE05 8200DC97 A5DF0010
  300D0609 2A864886 F70D0101 04050003 81810004 BEF22A40 C5014A11 D78BAF5B
  94B43844 209C3771 83286FD4 DC68D1D8 4013D4C4 0BCB5B7E 3BF101B3 119D83C1
  20DCEC1E 03B81A02 22ECA604 16C5CADA 13F169BC CFBAFF0A FAAF50A6 8F465E38
  F4A51DC1 7E481C78 8ED599AC 20B507FE C0D10A15 16D60004 EBEB08E8 A7751D8C
  7341D8C1 A9104379 7A473064 A30841FF C4EB9D
            quit
no ip source-route
ip dhcp excluded-address 192.168.1.1 192.168.1.99
ip dhcp excluded-address 192.168.1.200 192.168.1.254
ip dhcp pool ccp-pool1
   import all
   network 192.168.1.0 255.255.255.0
   dns-server 72.240.13.5 72.240.13.7
   default-router 192.168.1.1
ip cef
no ip bootp server
ip domain name compgallery.com
ip name-server 72.240.13.5
ip name-server 72.240.13.7
ip port-map user-protocol--1 port tcp 5900
no ipv6 cef
license udi pid CISCO881-K9 sn FTX160285BS
username compgallery privilege 15 secret 5 $1$SyVp$c0pXe/HXOr7qA6pEjfssB.
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
class-map type inspect match-all sdm-nat-http-1
match access-group 101
match protocol http
class-map type inspect match-all sdm-nat-user-protocol--1-1
match access-group 102
match protocol user-protocol--1
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol h323
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect sdm-pol-NATOutsideToInside-1
class type inspect sdm-nat-http-1
  inspect
class type inspect sdm-nat-user-protocol--1-1
  inspect
class class-default
  drop
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class class-default
  drop
class class-default
  drop
zone security out-zone
zone security in-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security sdm-zp-NATOutsideToInside-1 source out-zone destination in-zone
service-policy type inspect sdm-pol-NATOutsideToInside-1
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ES_WAN$$FW_OUTSIDE$
ip address 72.240.126.183 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly
zone-member security out-zone
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
zone-member security in-zone
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source static tcp 192.168.1.20 80 interface FastEthernet4 80
ip nat inside source static tcp 192.168.1.20 5900 interface FastEthernet4 5900
ip nat inside source list 1 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 FastEthernet4
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip 72.240.126.128 0.0.0.127 any
access-list 101 remark CCP_ACL Category=0
access-list 101 permit ip any host 192.168.1.20
access-list 102 remark CCP_ACL Category=0
access-list 102 permit ip any host 192.168.1.20
no cdp run
control-plane
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you
want to use.
^C
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
0 Replies 0
