Cisco 881 router switch port
limlayhin
I understand that router 881 has 4 10/100Mbps Managed switch port and 1 WAN port.
If it is a normal router (without switch port), I know I can connect the router to 4 different LAN segments, each interface has its own IP addresses, eg 192.168.1.1/24, 192.168.2.1/24, 192.168.3.1/24, 192.168.4.1/24 and one port connect to WAN.
Can router 881 support up to 4 different VLAN so that I can achieve above requirements?
Each interface tie to one VLAN and all 4 VLAN has its own IP, eg VLAN1 - 192.168.1.1/24, VLAN2 - 192.168.2.1/24, VLAN3 - 192.168.3.1/24, VLAN4 - 192.168.4.1/24.
I can then connect each interface to a small hub which allow me to extend number of ports.
Thanks....
the 881 supports 300 Interface Descriptor Blocks (IDBs), so 4 VLANs are no problem. Here is a sample output from an 881:
interface Vlan1
interface Vlan2
ip address 192.168.2.1 255.255.255.0
interface Vlan3
ip address 192.168.3.1 255.255.255.0
interface Vlan4
ip address 192.168.4.1 255.255.255.0
interface Vlan5
ip address 192.168.5.1 255.255.255.0
interface Vlan6
ip address 192.168.6.1 255.255.255.0
interface Vlan1
interface Vlan2
interface Vlan3
interface Vlan4
interface Vlan5
interface Vlan6
This is great. Thanks for the input.
