Cisco 881 SSH not working to router from outside but works from inside, any suggestions looking at my config?
I am scratching my head over this one, but hopefully someone will see something I am missing.
version 15.3
no service pad
hostname myrouter
boot-start-marker
boot-end-marker
aqm-register-fnf
enable secret 5 itsasecret
aaa new-model
aaa session-id common
memory-size iomem 10
ip domain name mydomain.com
ip cef
no ipv6 cef
license udi pid C881-K9 sn myserial
username notcisco privilege 15 password 0 notmypassword
ip ssh version 2
no crypto engine onboard 0
crypto ipsec client ezvpn ezname
 connect auto
 group mygroup key itsprivate
 mode network-extension
 peer x.x.x.3
 xauth userid mode interactive
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 no ip address
interface FastEthernet4
 ip address x.x.x.1 255.255.255.0
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface Vlan1
 ip address x.x.x.2 255.255.255.0
 ip nat inside
 no autostate
 crypto ipsec client ezvpn ezname inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map NATTRANSLATE interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 x.x.x.4
route-map NATTRANSLATE permit 10
 match ip address 125
snmp-server group solarw v3 priv
access-list 100 deny   ip x.x.x.2 0.0.0.255 172.16.125.0 0.0.0.255
access-list 100 deny   ip x.x.x.2 0.0.0.255 172.16.150.0 0.0.0.255
access-list 100 deny   ip x.x.x.2 0.0.0.255 172.16.175.0 0.0.0.255
access-list 100 deny   ip x.x.x.2 0.0.0.255 172.16.200.0 0.0.0.255
access-list 100 deny   ip x.x.x.2 0.0.0.255 10.10.0.0 0.0.255.255
access-list 100 permit ip x.x.x.2 0.0.255.255 any
access-list 125 deny   ip x.x.x.2 0.0.0.255 10.10.20.0 0.0.0.255
access-list 125 deny   ip x.x.x.2 0.0.0.255 10.10.1.0 0.0.0.255
access-list 125 deny   ip x.x.x.2 0.0.0.255 172.16.125.0 0.0.0.255
access-list 125 deny   ip x.x.x.2 0.0.0.255 172.16.150.0 0.0.0.255
access-list 125 deny   tcp any eq telnet any
access-list 125 deny   tcp any eq 22 any
access-list 125 deny   ip any 10.0.0.0 0.0.0.255
access-list 125 deny   ip any 192.168.0.0 0.0.255.255
access-list 125 deny   ip any 172.16.0.0 0.15.255.255
access-list 125 permit ip any any
access-list 150 permit ip x.x.x.2 0.0.0.255 10.10.0.0 0.0.255.255
access-list 150 permit ip x.x.x.2 0.0.0.255 172.16.125.0 0.0.0.255
access-list 150 permit ip x.x.x.2 0.0.0.255 172.16.150.0 0.0.0.255
access-list 150 permit ip x.x.x.2 0.0.0.255 172.16.175.0 0.0.0.255
access-list 150 permit ip x.x.x.2 0.0.0.255 172.16.200.0 0.0.0.255
access-list 199 permit esp host x.x.x.5 host x.x.x.6
access-list 199 permit udp host x.x.x.5 host x.x.x.6
access-list 199 permit icmp any any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
 exec-timeout 0 0
 no modem enable
line aux 0
line vty 0 4
 exec-timeout 0 0
 password notforyou
 transport input ssh
scheduler max-task-time 5000
scheduler allocate 20000 1000
end
get_rthym
Hello
Just gave a glance and though below might be the cause.
change to this and see it works "access-list 125 permit   tcp any eq 22 any"
hth
I believe that sometimes there can be complications when NAT is done with extended access lists which do permit any any. I wonder what would happen if the original poster changes this line in the access list
and replaces the source "any" with the IP subnet(s) that should get translated?
Rick
Rick
Thanks Richard but no go. I am running similar configs on many routers. This is almost identical to another one of the same model I have in use on the same service provider, the devil, er, I mean Comcast.
The only difference I can see is that one is a single IP and the Comcast router is in virtual bridge mode and the other is 5 ips and that one is just natting things.
I may just have Comcast kill their virtual bridge and test it.
In this case it did not help, thank you though.
