Cisco 881 VPN: can't access local resources
knutjakobsen
    hi,
I have a Cisco 881 and I want to use Easy VPN.
VLAN 1: 192.168.4.0
WAN: 10.0.0.0
VPN: 192.168.8.0
VPN connects and I get an IP of 192.168.8.100 from my pool. I can ping my cisco at VLAN1 (192.168.4.1), but I cannot access my local resources. I guess I miss a NAT configuration, so please guide me into the right place...
thanks in advance!
11 Replies 11
ohassairi
Level 5
Level 5
use the graphical wizard from web management  interface
well, that didnt work well.
I did a re-run of the Easy VPN Wizard. After that I run the "test vpn server" and that also works, but when I try from my client computer, I got the Error 412. So now I'am 1 big step back in my setup......
Any ideas? This time I can't ANY EZVPN rules under "firewall".
What do I need to add?
anyone that can help?
I need to now which firewall-rules I need to configure, and I need to now the NAT rules.
Here is how you would configure the NAT exemption:
access-list 101 deny ip 192.168.4.0 0.0.0.255 192.168.8.0 0.0.0.255
access-list 101 permit ip 192.168.4.0 any
ip nat inside source list 101 interface overload
Please kindly make sure that you remove other dynamic NAT statement if you have one.
Hope that helps.
that's great. I will try this later. Thanks!
but what firewall rules do I need? (outgoing --> in )
edit: After I re-run the EZVPN wizard, I cant connect at all to the vpn server because of missing firewall rules, and not only NAT rules.
For firewall rules, I would need to see which type of firewall configuration you have configured, ie:
1) ACL?
2) CBAC?
3) ZBFW?
If you can post the config that would help.
the VPN pool is 10.1.1. net. (SDM2), I will delete 192.168.8.0
Current configuration : 12171 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname cisco
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
logging message-counter syslog
logging buffered 51200
logging console critical
enable secret 5 $1$zAmu$pZfX8OsCLHrEUm8OmINKX1
aaa new-model
aaa authentication login local_authen local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authorization exec local_author local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa session-id common
clock timezone PCTime 1
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
crypto pki trustpoint TP-self-signed-2367260332
  enrollment selfsigned
  subject-name cn=IOS-Self-Signed-Certificate-2367260332
  revocation-check none
  rsakeypair TP-self-signed-2367260332
crypto pki certificate chain TP-self-signed-2367260332
  certificate self-signed 01
   30820242 308201AB A0030201 02020101 300D0609 2A864886 F70D0101 04050030
   31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
   69666963 6174652D 32333637 32363033 3332301E 170D3130 30383133 31323135
   32395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
   4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 33363732
   36303333 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
   8100AE82 3E293651 7361723A 3B455E28 1DA14F7C 5B63011F 9191EB20 DE6722D9
   97F7BCCD 9EBC3ED9 BBC8E0DE BCE54BED 41D1F00B A9E24811 265252DC 13CC3EC6
   E65C2B3A 4D8CB7CF 2B094789 086B5B14 527EFB3D 6E9339D8 3FA303C6 2710B774
   BEC0573F 461F4326 820ACF8D 74372B15 4CD7CCD5 07FBA595 6677410A 272B7CB5
   B2450203 010001A3 6A306830 0F060355 1D130101 FF040530 030101FF 30150603
   551D1104 0E300C82 0A636973 636F2E70 69636F30 1F060355 1D230418 30168014
   E6CC7F83 40BD59B9 D895BE30 88897BF4 94F66187 301D0603 551D0E04 160414E6
   CC7F8340 BD59B9D8 95BE3088 897BF494 F6618730 0D06092A 864886F7 0D010104
   05000381 81003FD8 241644AC E6AAD3D2 37804720 730A12AD 9C29841C F4A204CB
   17F489C0 2B71500E ED69C41E 35EA9643 1C7EE676 6D24A1EB 8AB95B83 0504750B
   F9734E08 DE6B9AD0 72B49CDD 971B80F8 A8507F0B 8396A69A 8F195877 DB43B3F0
   8E78417A B5D21AA8 42554F7E F9286298 4F3FF9FB 34897799 03209B4D 0CFB0825
   35156FD0 7611
    quit
no ip source-route
ip dhcp excluded-address 192.168.10.1 192.168.10.99
ip dhcp excluded-address 192.168.10.201 192.168.10.254
ip dhcp excluded-address 192.168.4.1 192.168.4.149
ip dhcp excluded-address 192.168.4.211 192.168.4.254
ip dhcp pool ccp-pool1
    import all
    network 192.168.4.0 255.255.255.0
    dns-server 217.13.7.140
    default-router 192.168.4.1
ip dhcp pool ccp-pool2
    import all
    network 192.168.10.0 255.255.255.0
    default-router 192.168.10.1
ip cef
no ip bootp server
ip domain name pico
ip name-server 217.13.7.140
ip name-server 217.13.4.24
license agent notify http://192.168.10.101:9710/clm/servlet/HttpListenServlet dummy dummy 2.0
username admin privilege 15 secret 5 $1$Rks/$bdc0PDqolQ7ncKYBIv36v1
crypto isakmp policy 1
  encr 3des
  authentication pre-share
  group 2
crypto isakmp client configuration group picomed
  key *****
  pool SDM_POOL_2
  acl 101
crypto isakmp profile ciscocp-ike-profile-1
    match identity group picomed
    client authentication list ciscocp_vpn_xauth_ml_1
    isakmp authorization list ciscocp_vpn_group_ml_1
    client configuration address respond
    virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile CiscoCP_Profile1
  set transform-set ESP-3DES-SHA
  set isakmp-profile ciscocp-ike-profile-1
crypto ctcp port 10000
archive
  log config
   hidekeys
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
class-map type inspect match-any SDM_BOOTPC
  match access-group name SDM_BOOTPC
class-map type inspect match-any SDM_SSLVPN
  match access-group name SDM_SSLVPN
class-map type inspect match-any SDM_DHCP_CLIENT_PT
  match class-map SDM_BOOTPC
class-map type inspect match-all SDM_GRE
  match access-group name SDM_GRE
class-map type inspect match-any vpn
  match protocol ssp
  match protocol isakmp
  match protocol gdoi
  match protocol ipsec-msft
  match class-map SDM_GRE
  match class-map SDM_SSLVPN
  match protocol gtpv0
  match protocol gtpv1
  match protocol l2tp
  match protocol pptp
class-map type inspect match-any CCP_PPTP
  match class-map vpn
  match protocol login
  match protocol gdoi
  match protocol ssp
  match protocol tcp
  match protocol udp
  match protocol radius
  match protocol ident
  match protocol ace-svr
  match protocol kerberos
  match protocol tacacs
  match protocol tacacs-ds
  match protocol clp
class-map type inspect match-any SDM_AH
  match access-group name SDM_AH
class-map type inspect match-any ccp-skinny-inspect
  match protocol skinny
class-map type inspect match-any sdm-cls-bootps
  match protocol bootps
class-map type inspect match-any vpn-inn-1
  match class-map vpn
  match protocol udp
class-map type inspect match-all ccp-cls--2
  match class-map vpn-inn-1
  match access-group name vpn
class-map type inspect match-any ccp-cls-insp-traffic
  match protocol pptp
  match protocol cuseeme
  match protocol dns
  match protocol ftp
  match protocol https
  match protocol icmp
  match protocol imap
  match protocol pop3
  match protocol netshow
  match protocol shell
  match protocol realmedia
  match protocol rtsp
  match protocol smtp extended
  match protocol sql-net
  match protocol streamworks
  match protocol tftp
  match protocol vdolive
  match protocol tcp
  match protocol udp
class-map type inspect match-all ccp-insp-traffic
  match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-h323nxg-inspect
  match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
  match protocol icmp
  match protocol tcp
  match protocol udp
class-map type inspect match-any ccp-h225ras-inspect
  match protocol h225ras
class-map type inspect match-any SDM_ESP
  match access-group name SDM_ESP
class-map type inspect match-any ccp-h323annexe-inspect
  match protocol h323-annexe
class-map type inspect match-any ccp-h323-inspect
  match protocol h323
class-map type inspect match-all ccp-icmp-access
  match class-map ccp-cls-icmp-access
class-map type inspect match-all ccp-invalid-src
  match access-group 100
class-map type inspect match-any ccp-sip-inspect
  match protocol sip
class-map type inspect match-all ccp-protocol-http
  match protocol http
policy-map type inspect ccp-permit-icmpreply
  class type inspect ccp-icmp-access
   inspect
  class class-default
   pass
policy-map type inspect ccp-inspect
  class type inspect ccp-invalid-src
   drop log
  class type inspect ccp-protocol-http
   inspect
  class type inspect ccp-insp-traffic
   inspect
  class type inspect ccp-sip-inspect
   inspect
  class type inspect ccp-h323-inspect
   inspect
  class type inspect ccp-h323annexe-inspect
   inspect
  class type inspect ccp-h225ras-inspect
   inspect
  class type inspect ccp-h323nxg-inspect
   inspect
  class type inspect ccp-skinny-inspect
   inspect
  class class-default
   drop
policy-map type inspect ccp-pol-outToIn
  class type inspect CCP_PPTP
   pass
  class class-default
   drop log
zone security out-zone
zone security in-zone
zone-pair security ccp-zp-self-out source self destination out-zone
  service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
  service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
zone-pair security ccp-zp-out-zone-To-in-zone source out-zone destination in-zone
  service-policy type inspect ccp-pol-outToIn
interface Null0
  no ip unreachables
interface FastEthernet0
  switchport access vlan 2
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
  description $ES_WAN$$ETH-WAN$$FW_OUTSIDE$
  ip address 10.0.0.254 255.255.255.0
  ip verify unicast reverse-path
  no ip redirects
  no ip unreachables
  no ip proxy-arp
  ip flow ingress
  ip nat outside
  ip virtual-reassembly
  zone-member security out-zone
  duplex auto
  speed auto
  snmp trap ip verify drop-rate
interface Virtual-Template1 type tunnel
  description $FW_INSIDE$
  ip unnumbered Vlan1
  no ip redirects
  no ip proxy-arp
  ip flow ingress
  tunnel mode ipsec ipv4
  tunnel protection ipsec profile CiscoCP_Profile1
interface Vlan1
  description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
  ip address 192.168.4.1 255.255.255.0
  no ip redirects
  no ip unreachables
  no ip proxy-arp
  ip flow ingress
  ip nat inside
  zone-member security in-zone
interface Vlan2
  ip address 192.168.10.1 255.255.255.0
  no ip redirects
  no ip unreachables
  no ip proxy-arp
  ip flow ingress
  ip nat inside
ip local pool SDM_POOL_1 192.168.8.100 192.168.8.200
ip local pool SDM_POOL_2 10.1.1.10 10.1.1.20
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet4 10.0.0.1 permanent
ip http server
ip http access-class 3
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
ip access-list extended SDM_AH
  remark CCP_ACL Category=1
  permit ahp any any
ip access-list extended SDM_BOOTPC
  remark CCP_ACL Category=0
  permit udp any any eq bootpc
ip access-list extended SDM_ESP
  permit esp any any
ip access-list extended SDM_GRE
  permit gre any any
ip access-list extended SDM_SSLVPN
  permit tcp any any eq 4443
ip access-list extended vpn
  remark CCP_ACL Category=128
  permit ip any any
logging trap debugging
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.4.0 0.0.0.255
access-list 1 permit 192.168.10.0 0.0.0.255
access-list 2 remark INSIDE_IF_Vlan2
access-list 2 remark CCP_ACL Category=2
access-list 2 remark NAT
access-list 2 permit 192.168.4.0 0.0.0.255
access-list 3 remark HTTP Access-class list
access-list 3 remark CCP_ACL Category=1
access-list 3 permit 192.168.10.0 0.0.0.255
access-list 3 permit 192.168.4.0 0.0.0.255
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip 10.0.0.0 0.0.0.255 any
access-list 101 remark CCP_ACL Category=4
access-list 101 permit ip 192.168.4.0 0.0.0.255 any
no cdp run
control-plane
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username privilege 15 secret 0
Replace and with the username and password you
want to use.
^C
banner login ^CAuthorized access only!
  Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
  no modem enable
  transport output telnet
line aux 0
line vty 0 4
  login authentication local_authen
  transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
From the configuration, it seems that the NAT configuration advised earlier has not been changed, and if you have changed the IP Pool to 10.1.1.0/24, please also change the ACL statement accordingly.
Currently you have:
Please change it to:
access-list 105 deny ip 192.168.4.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 105 permit ip 192.168.4.0 any
ip nat inside source list 105 interface FastEthernet4 overload
I would suggest that you remove the ZBFW configuration first to test the VPN connection as that only complicates the setup. Currently your ZBFW configuration is incorrect, and here is a sample configuration for ZBFW with VPN configuration:
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps5708/ps5710/ps1018/prod_white_paper0900aecd8062a909.html
This is exactly what I was trying to accomplish as well.
Minor typo in your configuration updates to append to Knut's configuration:
access-list 105 permit ip 192.168.4.0 0.0.0.255 any
However, by accicdent I discovered that this will also work by editing the IPSec ACL:
access-list 101 deny ip 192.168.4.0 0.0.0.255 10.1.1.0 0.0.0.255
Although both work, It feels better to me to stick the rule under IPSec although under the hood it is all probably the same master ACL
Thanks for your assistance!!!
Now if only I could get the Default Gateway to be accessible from VPN.... ( for another thread )
- JsD
I am back tracking on my post. I am still having issues. It seems the first time I connect to VPN after configuring, it works fine. If i disconnect and re-connect, I get the issue again and it does not clear until I restart the router
Definitely sounds like a routing issue...
I will try to resolve this on a newer ticket.
Update for those reading this thread. My issue is resolved here under discussion 3243266.
Looking at the configuration above, it is quite possible that this users configuration had the same issue as mine: Remove virtual tempate configuration from IPSec VPN.
- Tim
