Cisco 881 WAN issue
pierreculot
I have no access to WAN with my cisco 881(Cisco 881 sec K9; IOS                       15.0(1)M8). The 881 is in PPPoE
I followed the discussion: https://supportforums.cisco.com/message/3465409#3465409.
I thing my config is almost the same...
But unfortunaly  I can't ping 8.8.8.8 i.ex., from the router.
In the PPP log I saw the login with success to ISP and it receives an IP address.
This is my config:
ip source-route
ip dhcp excluded-address 192.168.9.1 192.168.9.99
ip dhcp pool ccp-pool1
   import all
   network 192.168.9.0 255.255.255.0
   default-router 192.168.9.1
ip cef
ip name-server 8.8.8.8
no ipv6 cef
license udi pid CISCO881-SEC-K9 sn FCZ161991C1
username pcu privilege 15 secret 5 xxxx.
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ES_WAN$$FW_OUTSIDE$
no ip address
ip virtual-reassembly
ip tcp adjust-mss 1412
duplex auto
speed auto
pppoe-client dial-pool-number 1
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 192.168.9.1 255.255.255.0
ip nat inside
interface Dialer0
ip address dhcp client-id FastEthernet4
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname xxx
ppp chap password 7 xxx
ppp pap sent-username xxx@SKYNET password 7 xxx
no cdp enable
router rip
network 192.168.9.0
no auto-summary
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns server
ip nat inside source list 1 interface Dialer0 overload
ip route 0.0.0.0 0.0.0.0 Dialer0
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.9.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
control-plane
Pierre#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, + - replicated route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S*    0.0.0.0/0 is directly connected, Dialer0
      192.168.9.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.9.0/24 is directly connected, Vlan1
L        192.168.9.1/32 is directly connected, Vlan1
Someone can help me?
Thank you.
Pierre
Jose Bogantes
Hello Pierre,
Please use "ip address negotiated" under interface dialer instead of using "ip address dhcp client-id FastEthernet4".
Please use " ip mtu 1492" instead of 1452.
Are you getting a valid IP address in the dialer after making those changes?
Regards.
Jose Bogantes
Hello Pierre,
Regards.
Hello Jose,
Thank you very much, it works.
I tried "ip address negotiated" at starting of config but without success. Probably something else wrong.
Pierre
